High voltage Ac generation to apply to a capacitor
The discussion revolves around generating high voltage AC for a primarily capacitive load at approximately 190 kHz. Participants explore various methods to achieve voltages of at least 1 kV, with some expressing interest in applications related to electric fields in winemaking. The conversation includes considerations of resonant circuits, transformers, and safety concerns.
  • Experimental/applied
  • One participant suggests using a step-up transformer to increase voltage, noting the impedance transformation effect based on the turns ratio.
  • Another proposes resonating a capacitor with an inductor to achieve higher voltages, mentioning the need for a quality factor (Q) of around 20.
  • A participant questions the phase relationship of voltage and current in a series resonant circuit, seeking clarification.
  • There is a mention of using a secondary winding in a transformer to further increase voltage after resonance.
  • Concerns are raised about high voltage safety and the potential for radio frequency interference (RFI).
  • One participant discusses the specific application of electric fields in winemaking, indicating a preference for achieving voltages around 10 kV.
  • Another participant suggests that reducing the gap between electrodes could allow for lower voltage to achieve the same electric field strength.
  • There is a reference to a schematic involving 555 timers and a television flyback transformer as a potential solution.
Participants express various viewpoints on methods to generate high voltage AC, with no consensus reached on the best approach. Multiple competing ideas are presented, and the discussion remains unresolved regarding the optimal solution.
Participants mention specific voltage requirements and safety considerations, but there are unresolved assumptions regarding the feasibility of proposed methods and the exact parameters needed for successful implementation.
Bailiwick
Hi this is my first post on here
I am looking to create a large voltage across a primarily capacitive load at around 190 kHz. At the moment i have a 175 Watt power amplifier which puts out 55 Vp.
The output impedance also needs to be quite low < 100 ohms
Does anyone have any idea how to do this. I am thinking maybe some sort of resonant circuit. Or maybe I will have to make a valve amplifier. The voltage should be at least 1 kV
Any RF engineers out there? help would be very much appreciated
thanks
mark
Whats wrong with a stepup transformer?
It transforms the impedance up by a square of the turns ratio so say I wanted 500V, ratio 1:10 wouldn't it transform the impedance up by a facto of 100
Why not Resonate the Capacitor with a suitable Inductor in series? You could get many times (XQ) the input voltage that way and an inductor is easy to make / buy. You need a Q of around 20, it would seem.
thanks
mark
What's the application?
sophiecentaur
Yes I have thought of this idea. which seems pretty good to me but is quite difficult to achieve high Q.
I was thinking if you put a secondary winding as in a transformer , would this step up the already increased voltage that is created across the inductor?
Also what is the voltage current phase relationship in a series resonant circuit. inphase?
Berkemen
Application is electric fields across wine which were doing a bit more of,
http://www.stuff.co.nz/waikato-times/business/3190621/Better-wine-in-a-flash
Id actually prefer the voltage to be in the order of 10 kV but this may be slightly harder to achieve.
It definitely tastes different the hard part is getting the frequency and E field correct to make it taste better. We have found a reasonably good combination that i can't really disclose
This was confirmed on national tv by a wine critic
But I need ideas to get a wacking great AC voltage for further development
Hopefully you and your advisors know a bit about high voltage safety, and about how to avoid creating RFI (radio frequency interference).
Keep in mind also that if you can put that voltage across a smaller gap, then it takes a lot less voltage to make the same E field. So can you make a bunch of panels or something inside the wine container that are spaced closer together, and use a more standard voltage...?
Interesting. Does the quick-made wine taste different?
When I saw this:
Professor of electronics Jonathan Scott ...
I about spit on my monitor. It does sound like a neat project.
BTW I'll volunteer to be a taster. :biggrin:
Berkemen its across a 4mm gap and the breakdown voltage of these is 25 kV/cm so we want to have control of the voltage up to this point ~14kV
dlgoff Jonathan has actually finished with the project now unfortunately, otherwise I wouldn't be on here trying to conjure up some ideas.
I was sort of joking with berkeman since we have a member here with the same "name". :smile:
This schematic for a http://www.repairfaq.org/sam/hvgen32.pdf" uses a couple of 555 timers and a television flyback transformer.
Source: http://www.repairfaq.org/sam/samschem.htm#schahg"
  • · Replies 49 ·
  • · Replies 32 ·
  • · Replies 47 ·
  • · Replies 51 ·
