What polymer should I use instead of polycarbonate
  • Thread starter Thread starter jjssj
    Polymer
The discussion centers around identifying a suitable polymer to replace polycarbonate for use in rodent housing. Participants explore various materials, their properties, and the challenges associated with maintaining clarity and durability under specific conditions.
  • Experimental/applied
  • One participant outlines the requirements for the polymer, emphasizing the need for high transparency, scratch resistance, ease of cleaning, safety, durability, and affordability.
  • Another participant mentions that commercially available models often use acrylic, which is cheaper than polycarbonate but has drawbacks such as being easily cracked and scratched.
  • Some participants discuss the potential of using thick glass, noting its high manufacturing costs and weight as significant drawbacks.
  • One participant suggests that lexan™ (a brand of polycarbonate) might still be the best option despite its cost, indicating a preference for its properties.
  • Concerns are raised about the cleaning process and how it affects the material's clarity and integrity over time.
Participants express differing opinions on the suitability of various materials, with no consensus reached on a definitive replacement for polycarbonate. Some advocate for acrylic, while others highlight its disadvantages. The discussion remains unresolved regarding the best alternative polymer.
Participants note limitations related to the specific requirements for clarity and durability, as well as the potential trade-offs in strength and cost among different materials. The discussion reflects ongoing exploration rather than established conclusions.
jjssj
The polymer is to be used for rodent housing (cage).
I need to find a polymer which has the properties shown below.
Polycarbonate
Before I go into the specification required, I have researched and have come up with polycarbonate.
As it has high impact strength, is 200x stronger than glass, and is cheaper. This polymer has many more features that are brilliant.
However there are problems with this material that I would like to overcome.
How long the material will stay clear when subdued to the following;
1. Hot water (50c)
2. Animal cleaning agents
3. Fairy liquid
4. Manual cleaning with sponge/cloth
5. Scratches created by the rodent
Basically all the operations/chemicals above must not create any scratches or cause the polymer to fog up until a long time; it must stay clear as possible. White scratches are more of a problem than the depth of the scratch.
I am unclear on the information provided but I believe polycarbonate is not designed to stay clear under these circumstances.
The material would be cleaned at least once a week
One of the most aspects of not using polycarbonate is the price that it is at.
The material has a huge impact on final price of the product. As polycarbonate is quite expensive compared to other polymers, it makes the total cost of the product high, therefore customers will have to pay a higher price than the average price of a cage. (Even if the material is better)
These are the properties the polymer requires;
[Clear] As transparent as possible, let's in 100% light (If possible)
High Scratch Resistant
Easy to clean, with hot water, mild cleaning agents and not get scratched or change in the light coming through the polymer, until a long time.
Safe for human and animal contact
Durable, the material will last long
Strong and tough i.e. if dropped from a table it will not crack or cause any large imperfections on the surface.
Very malleable, easy to machine, mould
Not too brittle
Sorry for the long explanation I’m a college student.
Thanks for any help it will be much appreciated
What materials are used in commercially available models? The small aquarium I have is acrylic.
Yes majority of the current designs use acrylic however this material is the reason/problem why i want to design my own cage using different material
Advantage over polycarbonate
Even though acrylic is cheaper than polycarbonate or other materials.
Some disadvantages of acrylic
It is easily cracked through delivery (even when well packaged adding extra costs for this protection).
If mishandled whilst cleaning the cage i.e. dropped it can easily crack too, this may happen to someone cleaning the cage.
Gets scratched by majority of objects (the material is not very hard)
The problem with the current cages are;
Difficult to clean due to complex shapes/heaviness as a result of this the cage becomes difficult to see inside due to cleaning (manual, cleaning agents etc...)
Therefore it is difficult for people and the owner to see inside.
The reason i posted this is to find if there were any similar types of polymers that cost less than polycarbonate as this is the only disadvantage polycarbonate really has. The material can have lower valued features from the polycarbonate i.e. less impact strength.
The main aspect that the material must have is to remain clear as long as possible when being cleaned by us and scratched by the rodent,
Not easily damaged whilst being handled by people (mainly the surface, no white marks).
Good strength/ very good hardness
Chemically resistant to mild cleaning agents
The rest are written the first post
Thanks again for any help
Thick glass? Put in some rubber or silicone shock absorber strips, and it could probably survive a fall or few.
That was the first thing that came to mind however glass is has high manufacturing costs and delivery due to its heaviness.
The size is approx 600mm x 400mm x 580mm, (LxWxH 2 floors) and if it was made out of thick glass it would be so heavy i think an adult would just about be able to pick it up let alone a child. (20kg)
Im lookn at around 5kg for weight which is still heavy for a child however two children at both ends should be able to manage.
Im talking to various plastic companies so the product is still in the research/design stage
Thanks for the suggestion
I think lexan™/Polycarbonate is going to be your best bet.
11K
  • · Replies 0 ·
  • · Replies 19 ·
10K
