| Thread Closed |
Thermodynamics basics. |
Share Thread | Thread Tools |
| Jul9-10, 12:06 PM | #1 |
Hi!
I just need some basic things cleared and I would really appreciate if someone helped me out. Here are a few questions that put forward my doubts: 1. Thermodynamic equilibrium requires mechanical equilibrium--please explain. 2.How many state variables (Voume,pressure,temperature etc.) are needed to specify a thermodynamic system? 3. In order for Boyle's law to be applicable to a process,does the process need to be quasi static and (or) isothermal?(Referring to this,the main thing is--is an isothermal process always quasi static?) 4.What kind of factors does continuum volume (the minimum volume needed to obtain a continuum in the system) depend upon? 5. why is density a thermodynamic quantity?(It says so in my book). 6. What is the significance of classifying systems into 'open','closed' and 'isolated' systems?(I mean in real life,do we consider them while performing adiabatic/isothermal/isochoric processes?) 7. Lastly,what is the difference between the Helmoltz equation and gibb's equation(just basic idea required). Thanks. (Btw,there are a lot of questions,but I guess they're short ones!!) |
| Jul9-10, 10:43 PM | #2 |
| Jul9-10, 10:55 PM | #3 |
Does that mean that density is a thermodynamic quantity because the pressure or temperature changes cause an overall density change of the gas?
| Jul10-10, 12:29 AM | #4 |
I would say yes to your question. Volume is a thermodynamic variable, and when the volume changes the density changes, therefore density is a thermodynamic variable also.
| Jul10-10, 12:35 AM | #5 |
Thanks!
Could you answer some of my other questions too,please? |
| Jul10-10, 12:46 AM | #6 |
question 3: Boyle's law just requires that you are comparing two instants in time when the temperature T and the amount of substance n are the same in both cases: P1 V1 = nRT = some constant, P2 V2 = nRT = the same constant, P1 V1 = P2 V2. There is no dependency on the kind of process. The main problems that cause Boyle's Law to fail are when the pressure or density get too high (because electrical intermolecular forces may become significant) or when the temperature gets too low (because a real gas can liquify). Otherwise, the process doesn't affect the correctness of the equation.
| Jul10-10, 12:51 AM | #7 |
Your other questions, I'm afraid I might answer them incorrectly. There may be someone else here who has more certainty.
| Jul10-10, 02:42 AM | #8 |
The pressurized tank is not in equilibrium because the gas is denser, due to more mechanical impacts of the molecules. Once in mechanical equilibrium, then heating the tank adds velocity to the gas particles. Now the gas molecules are not in equilibrium, not because there is more, but because they are hitting harder and faster than the molecules outside. Now a closed system is when no parts are allowed in or out of the system, but energy is. The freon in an air conditioner is 'enclosed', but is what is used to transfer heat out of your house. That's what the big coils outside the house is for, as a heat exchanger. These last concepts need a better understanding of the previous questions. It would be best to learn how and why the equation of state of an ideal gas are manipulated the way they are. With 3 variables you can hold one of them constant to see how the other two work together. Then choose another variable to hold constant and learn how another pair of variables work together. When you learn how any combination of two variables work together, you can start treating all 3 as variables. That's how you learn about the answers to these questions you are asking. |
| Jul10-10, 03:09 AM | #9 |
The difference in Helmholtz and Gibbs energy:
In general, the equilibrium state of a system is the state of maximum entropy. Since entropy is not a quantity that can be easily understood or measured in real situations, we can define other thermodynamic potentials that are relevant to the conditions at hand. Gibbs energy and Helmholtz energy are two such potentials. You can show that, in the right conditons, the entropy maximum condition for equilibrium is equivalent to either the minimum Gibbs free energy or the minimum Helmholtz free energy. In chemical reactions that occur commonly on earth, the pressure is fixed at atmospheric pressure, and the temperature is fixed by the surroundings. Then P and T are the controlled variables. In this situation, you can show that maximum entropy is equivalent to minimum Gibbs free energy. Thus, it is the Gibbs energy that is generally used to analyze the system. In a pressure cooker, the situation is different. In this case, the volume is fixed by the container. Temperature and volume are the controlled variables, and the system will spontaneously evolve until the Helmholtz energy is minimized. In general, it's all about maximizing entropy, but how that manifests itself depends on the physical constraints of the system. |
| Jul10-10, 08:52 AM | #10 |
mechanical equilibrium ) can be affected in many ither ways also,hence it is different from thermal equilibrium. The other answers were also very helpful. Thanks,my_wan! |
| Jul10-10, 09:00 AM | #11 |
Thanks,johng23! |
| Jul10-10, 01:17 PM | #12 |
Recognitions:
| Jul12-10, 11:54 AM | #13 |
Btw,why is it that "state space has an odd number of dimensions, whereas the mechanical state space has an even number" is important to note? Thanks for the help,Andy Resnick! |
| Jul12-10, 09:31 PM | #14 |
Recognitions:
As to the difference in even- versus odd- dimensioned phase space, I can only give a partial answer: in mechanical theories, phase states with an even number of dimensions have a symplectic structure: there are conjugate pairs of variables (i.e. position and momentum, q and p). Odd-dimensioned spaces have a contact structure: http://en.wikipedia.org/wiki/Symplectic_vector_space http://en.wikipedia.org/wiki/Contact_geometry |
| Jul13-10, 01:45 AM | #15 |
Recognitions:
Andi, what do you say! To specify the equilibria of the simplest systems two out of the three variables p, V, T are sufficient. The heat is not needed to specify U uniquely. Of course there are more complicated systems which need more variables for a complete specification of the equilibrium state, so there may also be electric and magnetic field variables, stress and strain etc. Thermodynamics does not fix this number but one has to find them for the specific system. Hence one sometimes says that thermodynamics is a meta-theory.
| Jul13-10, 07:59 AM | #16 |
Recognitions:
Please see, for example,
http://arxiv.org/abs/math-ph/0703061 For a single phase, the 5 variables are pressure/volume, temperature/entropy, and U. |
| Jul17-10, 06:19 AM | #17 |
want to ask a question..is it true the absolute pressure in a liquid of c0nstant density d0ubles when the depth is d0ubled?explain please..
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thermodynamics basics.
| Thermodynamics: violation of 1st and/or 2nd law of thermodynamics in a heat engine | Introductory Physics Homework | 7 | ||
| Prof teaches Statistical thermodynamics in a Classical Thermodynamics class | Academic Guidance | 10 | ||
| basics of thermodynamics | Mechanical Engineering | 2 | ||
| basic thermo problem | Classical Physics | 10 | ||
| Thermodynamics basics | Introductory Physics Homework | 3 | ||
