Inequality Mathematical Induction
The discussion revolves around proving the inequality n! > 2^n for integer values of n, specifically for n ≥ 4, using mathematical induction.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to establish the base case for n=4 and assumes the statement holds for n=k. They express uncertainty about the next steps in proving the case for k+1. Some participants question the reasoning behind multiplying by 2 and suggest focusing on the factorial expression (k+1)! instead. Others clarify that proving (k+1)! > 2^{k+1} is the goal, and they explore the implications of rewriting the inequality.
Participants are actively engaging with the problem, offering hints and clarifications regarding the approach to take. There is a recognition of the need to prove (k+1)! > 2^{k+1}, and some guidance has been provided on how to manipulate the factorial expression. Multiple interpretations of the steps are being explored without a clear consensus on the next best move.
The discussion is constrained by the requirement to prove the inequality specifically for n ≥ 4, and participants are navigating the implications of this constraint in their reasoning.
themadhatter1
Prove the Inequality for the indicated integer values of n.
[tex]n!>2^n,n\geq4[/tex]
For n=4 the formula is true because
[tex]4!>2^4[/tex]
Assume the n=k
[tex]k!>2^k[/tex]
Now I need to prove the equation for k+1
I can multiply both sides by 2 and have
[tex]2(k!)=2(k!)>(2)2^k=2^{k+1}[/tex]
Is this what you would do next? I'm not quite sure what to do past this point.
[tex]2(k!)>2^{k+1}>k+1[/tex]
Why would you multiply by 2?
It's not 2k! you want to make a statement about, but (k + 1)! = (k + 1) k!
I don't know. When dealing with regular equations you would just set k=(k+1) but that's not the case here I think.
Wouldn't you be trying to prove that [tex](k+1)!>2^{k+1}[/tex]? Why would I be making a statement about '(k + 1)! = (k + 1) k!'? Where is the 2 raised to the power of (k+1) and why is there 2 factorials when there isn't in the original problem?
Sorry, you are approaching the problem from a different angle than I expected.
Once you have 2 (k!) > 2k + 1, you only need to prove that (k + 1)! > 2 k! to be done with it.
The hint I gave, that (k + 1)! is equal to (k + 1) times k!, is still useful.
Ahh, so you could rewrite
(k + 1)! > 2 k!
as
k!(k+1) > 2 k!
Here you can see the when k > 1, k!(k+1) > 2 k! and since the original formula is only supposed to work for numbers greater than or equal to 4 its fine.
Thanks.
We are required to show that [tex]n!>2^{n}[/tex], for the k+1 term, multiply by k+1 to obtain:
[tex] (k+1)k!=(k+1)!>2^{k}(k+1)>2^{k+1}[/tex]
Since k+1>2 for k>2 and we are done
