Thread Closed
Limit Comparison/Comparison Test on Non-rational functions
Share Thread Thread Tools
Jul14-10, 10:51 PM   #1
Either the Comparison Test or Limit Comparison Test can be used to determine whether the following series converge or diverge.
[i] which test you would use (CT or LCT)
[ii] which series you would use in the comparison.
[iii] does the series converge or not
The series of (root(n^4 +1) - n^2) n goes from 1 to infinity
2. Relevent equations
Series of 1/n^2? I am not too sure
3. The attempt at a solution
So what i did was drag out the n^2 from the root so it becomes (n^2)(root(1+(1/n^4)))
and I know i Think i have to compare this with 1/n^2 , I know this series converge, but however I do not know how to explain correctly, to compare it with 1/n^2, if 1/n^2 really is the right one to compare to, or should i be using limit comparison test? I am quite lost at the moment, I have tried everything, but the fact that all I can use is CT and LCT, I really don't know how to solve it. I know that root (n^4 + 1) is just really close to n^2, its that (+1) that make this series happen.... Pleasee and thanks :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jul14-10, 11:07 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
I would start by multiplying your expression by (sqrt(x^4+1)+n^2)/(sqrt(x^4+1)+n^2) and doing some algebra in the numerator. Then see what you think.
Jul14-10, 11:12 PM   #3
I actually did that before, but i ended up with 2n^4 -(2n^2)(root(n^4 +1)) + 1 in the numerator, the fact that the square root is there really is making me struggle cus i dont know how to simplify it =\
Jul14-10, 11:13 PM   #4
Recognitions:
Quote by chrischoi614 View Post
Then show us the algebra you did to get that. It's not right.
Jul14-10, 11:28 PM   #5
no..... i didnt get it wrong :S.... i just put the terms together...
Jul14-10, 11:32 PM   #6
Recognitions:
I'm glad you are so confident but (sqrt(x^4+1)-n^2)*(sqrt(x^4+1)+n^2) doesn't have a sqrt in it if you expand it. Show us how you got 2n^4-(2n^2)(root(n^4 +1))+1 or we can't help you. Did you not change the sign on the n^2? That's the whole 'conjugate' thing that makes the sqrt cancel.
Thread Closed
Thread Tools
Similar Threads for: Limit Comparison/Comparison Test on Non-rational functions
Thread Forum Replies
(Limit) Comparison Test Calculus & Beyond Homework 5
direct and limit comparison test? Calculus & Beyond Homework 4
Estimating error using comparison/limit comparison test Calculus 0
Limit Comparison Test for series Precalculus Mathematics Homework 1
limit comparison test. Calculus & Beyond Homework 3
