Help Solving Charge Calculation Problem
The discussion revolves around calculating the unknown charge based on the force exerted by a known charge and addressing the components of forces in a multi-charge system. The subject area includes electrostatics and force calculations between charged particles.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the sign of the unknown charge and the importance of significant figures in calculations. There is also a query regarding the directionality of force components when calculating the total force on a charge.
Some participants have provided guidance regarding the sign of the charge and the need for precision in significant figures. There is an ongoing exploration of how to calculate the y component of the force acting on a charge, with multiple interpretations of the problem being considered.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a mention of potential rounding issues in calculations.
ACLerok
a charge of -0.55 * 10^-6 C exerts an upward force of magnitude .250 N on an unknown charge that is .3 meters directly below it. i am to find the unknown charge but I keep getting -5 *10^-6 which I keep getting told its wrong. Can someone give me a hand here? thANKS
I didn't check your numbers, but I can tell the sign of the charge you gave can't be right. The first charge is attracting the second charge, so they must have opposite signs.
As someone else mentioned, your sign is wrong. Other than that, your value is close but it looks like you rounded off too much. Given the data, you should have kept two sig figs.
Pat
Pat
alright thanks guys.. ill check it again.
Pat
well there you go. the answer was 4.55*10^(-6) C. THANKS!
oh and BTW.
A particle of charge 4.96 nC is placed at the origin of an xy-coordinate system, and a second particle of charge 2.02 nC is placed on the positive x-axis at 3.96cm . A third particle, of charge 6.01cm is now placed at the point 3.96cm , 3.01cm. I found the x component of the total force exerted on the third force by the first two. But now i must find the y component of the total force.
The components can be negative or positive correct indicating direction or should i disregard that when adding the forces together?
I'm having a lot of trouble finding the y component of the Force exerted by charge 2 on 3. Can someone help me out?
The answers I did find are
F(1on3)x=8.685*10^-5
F(2on3)x=0
F(1on3)y=-6.601*10^-5
F(2on3)y=9.641*10^-5
THANKS!
  • · Replies 16 ·
