Properties of probability measures
  • Context: Graduate
  • Thread starter Thread starter Mathechyst
    Probability Properties
The discussion revolves around the properties of probability measures, specifically focusing on the relationship between countable additivity and finite additivity. Participants explore the challenge of proving that a probability measure is finitely additive given its countable additivity.
  • Doug presents the problem of proving that a probability measure is finitely additive, given its countable additivity.
  • One participant suggests considering sets that act as an identity under union to relate infinite unions to finite unions.
  • Another participant proposes looking at numbers that act as an identity under addition to relate infinite sums to finite sums.
  • Doug notes that proving P(∅) = 0 is necessary for the proof to be straightforward.
  • Another participant questions the implications if P(∅) ≠ 0.
  • Doug concludes with a suggestion that this leads to a contradiction.
Participants express uncertainty regarding the implications of P(∅) and whether it being non-zero affects the proof. There is no consensus on the resolution of the problem presented.
The discussion highlights the dependence on the assumption that P(∅) = 0, which remains unproven and is critical to the argument being made.
Mathechyst
I hate it when a fact is so obvious that it isn't obvious how to prove it. Like showing that a subset of a finite set is finite. So ... here goes:
A probability measure [itex]P[/itex] on a [itex]\sigma[/itex]-field [itex]\mathcal{F}[/itex] of subsets of a set [itex]\Omega[/itex] is a function from [itex]\mathcal{F}[/itex] to the unit interval [itex][0,1][/itex] such that [itex]P(\Omega)=1[/itex] and
[tex] P\left(\bigcup_{m=1}^{\infty}A_m\right)=\sum_{m=1}^{\infty}P\left(A_m\right)[/tex]
for each pairwise disjoint sequence [itex](A_m:m=1,2,3,\ldots)[/itex] of members of [itex]\mathcal{F}[/itex]. Because [itex]P[/itex] satisfies this summation condition it is said to be countably additive.
The problem is to show that [itex]P[/itex] is finitely additive, that is:
[tex] P\left(\bigcup_{m=1}^{n}A_m\right)=\sum_{m=1}^{n}P\left(A_m\right)[/tex]
for each pairwise disjoint finite sequence [itex](A_1,\ldots,A_n)[/itex] of members of [itex]\mathcal{F}[/itex].
Anyone have any hints to toss my way? Thanks.
Doug
Well, you might look at the LHS, and try to consider sets that act as an identity under union, so you can set an infinite union equal to a finite union.
Or, you might look at the RHS and consider numbers that act as an identity under addition, so that you can set an infinite sum equal to a finite sum.
The proof would be trivial if [itex]P(\emptyset)=0[/itex] but that too is a fact that must be proved.
Doug
Hrm, do you know any disjoint sequences of sets whose union is the empty set?
I would say there's only one: [itex](\emptyset,\emptyset,\ldots)[/itex].
Doug
So what happens if [itex]P(\emptyset) \neq 0[/itex]?
Aha. A contradiction. :smile:
