Is the Graph of a Continuous Function Closed if the Spaces are T2 and T1?
  • Context: Graduate
  • Thread starter Thread starter radou
    Closed Graph
The discussion revolves around the question of whether the graph of a continuous function from a topological space X to a T2-space Y is closed in the product space X x Y. The participants explore various approaches to proving this property, examining the implications of continuity and the Hausdorff condition on Y.
  • One participant suggests that to show the graph G is closed, it is necessary to prove that its complement is open, leveraging the properties of T1 and T2 spaces.
  • Another participant points out that the preimage of {f(x)} is not necessarily the singleton set {x}, indicating a misunderstanding in the initial reasoning.
  • A different approach is proposed where G is viewed as the inverse image of the diagonal set {(y,y)} in Y x Y, suggesting that the closed nature of the diagonal in a Hausdorff space could be useful.
  • One participant attempts a proof using nets and the continuity of projections, exploring the implications of convergence in the context of the graph's closure.
  • Concerns are raised about whether the equality of projections from nets implies the equality of the nets themselves, highlighting potential gaps in the reasoning.
The discussion features multiple competing views and approaches to the problem, with no consensus reached on the validity of any particular method or conclusion.
Participants express uncertainty regarding the implications of continuity and the properties of nets in topological spaces, as well as the relationship between the components of converging nets.
radou
Me again.
Problem. Let X be a topological space, and Y a T2-space (i.e. a Haussdorf topological space). Let f : X --> Y be a continuous function. One needs to show that the graph of , i.e. the set G = {(x, f(x)) : x is in X} is closed in X x Y.
Attempt of proof. To show what we need to show, we have to prove that the complement of G is open. Now, since Y is a Haussdorf space, one can show that it is a T1-space too, i.e. that every set containing a single point is closed. So, for every x, {f(x)} is closed in Y. Further on, since f is continuous, the preimage of every closed set is a closed set too, so, for any f(x), {x} is closed in X. I feel I'm getting very warm, but I got stuck anyway. The complement of G in X x Y is X x Y \ G = X x Y \ U (x, f(x)) (where the union goes through all x in X) = [itex]\cap[/itex] [(X x Y) \ (x, f(x))]. Now, if X and Y are T1-spaces, can one show that X x Y is a T1 space, too? But then we'd in general have an infinite intersection of open sets, which doesn't need to be open.
Thanks in advance for a push.
Some comments: the preimage of {f(x)} is not necessarily x.
One way that I think will work is that G is the inverse image of {(y,y)} < Y x Y under a nice map. Using the fact that Y is Hausdorff I think you can show that the diagonal set ({(y,y)}) is closed.
Oh, of course! For some weird reason, I assumed f to be injective.
OK, I'll try to look into it.
Another attempt of a proof, a bit different than suggested.
So, to review, given f : X --> Y, with f continuous and Y Haussdorf (or T2), we have to show that the graph G of f is closed in X x Y (the closed graph theorem).
If we show that Cl(G) is a subset of G, then Cl(G) = G, and G is closed.
Let x = (a, b) be from Cl(G). Then there exists a net n : D --> G such that n --> (a, b). This implies the convergence of its components, i.e. n = (n1, n2) -- > (a, b). Since f is continuous, and n1 is a net in X which converges to a, the composition net f o n1 must converge to f(a). So, the net n' = (n1, f o n1) converges to (a, f(a)).
Let p1 and p2 be the projections from X x Y to X and Y respectively, defined with p1(x, y) = x and p2(x, y) = y. Since they are continuous, for every net N : D --> X x Y which converges to some (x0, y0), we have p1 o N --> x0 and p2 o N --> y0.
If we apply the projections p1 and p2 with the nets n and n', we obtain p1 o n --> a, p2 o n = b, p1 o n' --> a and p2 o n' --> f(a).
Now, the part I'm not exactly sure about (regardless of the same limits, of course) - does p1 o n equal p1 o n', since the first components od n and n' are equal? If so, can we conclude that n and n' are equal? If so, it follows easily from the other two relations that b = f(a), since Y is Haussdorf, so x = (a, b) = (a, f(a)) and hence lies in G.
Thanks in advance for anyone with enough patience for this.
Actually, after thinking a bit more, it seems pretty obvious that p1 o n = p1 o n' doesn't imply n = n', because it's only about the first components.
Still, I feel I could be on the right track with the work up to this absurd conclusion.
  • · Replies 20 ·
