What Is the Smallest Element of Set S in Induction Principle Homework?
The discussion revolves around finding the smallest element of the set S defined by the condition S={t∈Z+ | (3t-200)/2 ∈Z+}. The context involves principles of mathematical induction and properties of integers.
  • Participants explore how to determine the least integer in the set S, with some suggesting to analyze the function that defines S. Others express uncertainty about how to minimize the value of t.
The discussion includes various attempts to clarify the problem, with some participants suggesting graphical analysis and others questioning the assumptions behind the definitions provided. There is no explicit consensus on the approach to take.
Participants note that t must be even for the expression (3/2)t to yield an integer, and there is an ongoing exploration of the conditions under which the inequality (3/2)t - 100 > 0 holds true.
annoymage
S={t[tex]\in[/tex]Z+ | (3t-200)/2 [tex]\in[/tex]Z+}
how to i find the element of S, provided some of this theorem:
1. every nonempty set of non negetive integer contains a least element: that is, some integer a in S such that a=<b for all b's belongingmto S
2. if a and b any positive integer, then there exist a positive integer n such that na<b
3. induction principle
from theorem 1. how do i find the least integer??
Your goal is just to find the least element of S? I wouldn't use any of those. Look at the function that describes S... it's increasing with t, so you just want to make it as small as possible
can clarify a bit more,
i don't know how to make it small as possible
help T_T, someone,.. clarify for me. owho
Graph y = (3/2)t - 100 for t > 0. The graph is a portion of a straight line.
ok, i thought of that, hmm, i'll try to convey my inept attempt
the smallest possible are (3/2)t>100 for y to be positive
t must be even for (3/2)t to me integer,
so,
y=2,t=68
y=5,t=70
y=8,t=72
y=11,t=74
so, S={2n+68 l n[tex]\in[/tex]Z}
correct me please
so, i don't need use those above definition(except for induction)
For what t is (3/2)t - 100 > 0?
For what t in Z+ is the inequality above satisified?
  • · Replies 25 ·
