Is my U-238 Decay Chain Program Accurate After 4.468 Billion Years?
The discussion centers on the accuracy of a U-238 decay chain program that utilizes the Bateman equations for serial decay chains. After 4.468 billion years, the program outputs indicate that 50% of the remaining atoms are U-238, with 49.996% decaying to Pb-206, which aligns with expectations given the significant difference in half-lives. The user seeks validation of these results, particularly the near-total conversion to Pb-206, which is supported by the long half-life of U-238 compared to its decay products. The Decay Engine tool from Nucleonica is recommended for further verification of these calculations.
  • Understanding of Bateman equations for serial decay chains
  • Familiarity with nuclear decay processes and half-lives
  • Basic programming skills for implementing decay calculations
  • Knowledge of U-238 and its decay products
  • Verify decay chain calculations using the Nucleonica Decay Engine
  • Explore advanced applications of Bateman equations in nuclear physics
  • Research the implications of half-life differences in decay chains
  • Learn about other decay chain modeling tools and software
Researchers in nuclear physics, software developers working on decay simulations, and educators teaching nuclear decay concepts will benefit from this discussion.
jae1227
I wrote a program to find the percent of each element in the decay chain for U238 after a certain amount of time. I used the Bateman equations for serial decay chain below:
[tex] N_n(t)= \frac{N_1(t)}{\lambda_n } \sum_{i=0}^n \lambda_i \alpha_i \exp({-\lambda_i t})[/tex]
[tex] \alpha_i=\prod_{\substack{j=1 \\ j\neq i}}^n \frac{\lambda_j}{\lambda_j-\lambda_i}[/tex]
I have a working program but I don't know if the numbers are right. This is the output after 4.468e9 year, the half-life of U238:
U-238 50.0%
Th-234 7.38402118408e-10%
Pa-234m 2.4681490824e-14%
Pa-234 8.55341319395e-12%
U-234 0.0027474651976%
Th-230 0.000843614748358%
Ra-226 1.79287783423e-05%
Rn-222 1.17157024517e-10%
Po-218 6.59639173904e-14%
At-218 5.31967076451e-16%
Rn-218 1.24125650799e-17%
Pb-214 5.70268705015e-13%
Bi-214 4.23445792721e-13%
Po-214 5.82681270543e-20%
Tl-210 2.76622879307e-14%
Pb-210 2.4957038641e-07%
Bi-210 1.536048551e-10%
Po-210 4.2400210405e-09%
Tl-206 8.93491905013e-14%
Pb-206 49.9963907364%
I know that the 50% will be U238 but will 49.996% of the atoms be really be Pb206? The half-life of U238 is very long and the next longest in the chain is more than 4 magnitudes smaller, U234 with a half-life of 245500 years. Does anyone know if these results look about right.
Qualitatively it looks right, since U238 has (as you noted) a half life more than 4 magnitudes smaller. As a result you should expect that almost all the decayed U238 atoms would have already ended up as Pb206 - they don't spend much time in between.
9K
9K
