Arbitrary function of a matrix - power-series representation
The discussion revolves around evaluating the expression exp(i*f(A)), where A is a matrix with known real eigenvalues. The original poster is exploring the power-series representation of functions of matrices as a potential approach to this problem.
  • Participants discuss the expansion of the exponential function as a power series and consider the implications of A being diagonalizable. There are attempts to express f(A) in terms of its eigenvalues and to manipulate the expression for exp(i*f(A)). Questions arise regarding the nature of the function f and how to handle its arbitrary nature.
Several participants have contributed ideas on how to approach the problem, particularly through the diagonalization of A and the implications for f(A). There is an ongoing exploration of how to express the exponential of the function in terms of its eigenvalues, but no consensus has been reached on a definitive method.
There is uncertainty regarding the specifics of the function f, which affects the ability to proceed with the evaluation. The discussion reflects a mix of assumptions and explorations of generality in the context of matrix functions.
bjnartowt
I am trying to evaluate exp(i*f(A)), where A is a matrix whose eigenvalues are known and real.
You can expand functions of a matrix in a power-series. I think that's the way to get started on this problem. I foresee the exponential of a power-series expansion of f(A) suddenly becoming a product of exponentials of a matrix, which, themselves, are power-series. It sounds ugly, but perhaps some pleasant collapse will happen.
Okay, let's try finding power-series expansion of f(A):
[tex]f(A) = \sum\limits_{n = 0}^{n \to \infty } {\frac{{{f^{(n)}}(0)}}{{n!}}{A^n}} = {\rm{oh dear}}...{\rm{unaware of derivatives of f at 0}}{\rm{.}}[/tex]
Hmmm...maybe my idea above is not so great.
I think I am thwarted by the arbitrariness of the function "f(A)". Prior experience suggests arbitrariness is nothing to be afraid of...just an opportunity for higher generality...which is neato.
When you, dear reader, peruse this cry for help, do any suggestions come to your mind for a starting point to evaluating exp(i*f(A))? I just can't seem to bring "A" outside of "f" in order to take advantage of the fact that we know its eigenvalues.
do you know anything about f?
otherwise I would just expand the exponential as
[tex]e^{i f(A)} = \sum_{k=0} \frac{(if(A))^k}{k!}[/tex]
not sure this helps but playing with stuff
start by making the assumption A is diagonalisable - is it...? may lead to somthing interesting...
then there exists some S such that
[tex]S^{-1}AS = \lambda[/tex]
where lambda is diagonal, with main entries the eigenvalues of A
then
[tex]f(A) <br /> = f(S \lambda S^{-1}) <br /> = \sum_{n = 0} {\frac{f^{(n)}(0)}{n!}{(S \lambda S^{-1})^n}} <br /> = \sum_{n = 0} {\frac{f^{(n)}(0)}{n!}{(S \lambda^n S^{-1})}} <br /> = S \left( \sum_{n = 0} {\frac{f^{(n)}(0)}{n!}{( \lambda^n )}} \right)S^{-1}<br /> = Sf(\lambda)S^{-1}[/tex]
then applying same idea in the exponential
[tex]e^{i f(A)} = e^{i Sf(\lambda)S^{-1} }<br /> = \sum_{k=0} \frac{(i S f(\lambda)S^{-1} )^k}{k!}<br /> = S \left( \sum_{k=0} \frac{(if(\lambda))^k}{k!} \right) S^{-1}<br /> = S e^{i f(\lambda)}S^{-1}[/tex]
and I'm not sure whether that's helpful...
then you could also note for a diagonal matrix lambda
[tex]f(\lambda) = \begin{pmatrix}<br /> f(\lambda_1) & 0 & ... \\<br /> 0 & f(\lambda_2) & ... \\<br /> ... & ... & ... \end{pmatrix}[/tex]
which should be apparent from post #3
  • · Replies 24 ·
  • · Replies 22 ·
