How to Effectively Synchronize Multiple Generators in a Hospital Setting?
To effectively synchronize multiple generators in a hospital setting, it is crucial to ensure that the voltages, phases, frequencies, and phase sequences of the generators are aligned. The synchronization process involves creating a circuit that can manage these four essential synchronization steps. The new generator's rating should be determined based on the total load requirements of the hospital, especially with the addition of a new building. Manual operation of the current system without an Automatic Transfer Switch (ATS) or Uninterruptible Power Supply (UPS) presents challenges that need to be addressed in the synchronization design. A suitable title for the project could reflect the focus on generator synchronization in a hospital context.
dhanking23
i am BSEE student, my project study is to synchronize the generator of an hospital, it have a one 313KVA standby-power diesel gen.,and three 100kva transformer.The generator system is operated manually and no ATS or UPS. one more new building is being build so the transformer will be upgrade to a higher vale.
1)how i can connect the new gen. to the old gen. and to the synchronize panel?
2)what is the new gen. to be buy?(rating, etc.)
These is my title: To synchronize the generator system of the ____ Hospital.
Anyone have a good title?
Thanks.
Hello,
its a good and challenging project, first of all the synchronization of 2 generators consist of 4 parts:
1- the voltages should be equal in all phases in the 2 generators
2- the 2 generators should be in phase
3- the output of the 2 generators should have same frequency
4- the sequence of different generator phases in the two generators should be the same (meaning if the sequence of phases in generator 1 is :a-b-c, then the sequence of phases in generator 2 should also be:a,b,c)
So you have to make a circuit that do the 4 steps of synchronization.
with respect to the rating of the generator, it depends on the load you have in the building.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
