Velocity Factor & Wave Length: What's the Connection?
The discussion revolves around the concept of Velocity Factor and its relationship to wavelength in the context of electrical signals, particularly in coaxial cables or transmission lines. Participants explore the definitions, implications, and calculations involving Velocity Factor and dielectric constants.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • Some participants inquire about the definition of Velocity Factor and its influence on wavelength calculations.
  • Others suggest that Velocity Factor refers to the speed of signal propagation as a fraction of the speed of light.
  • A participant questions the formula for wavelength when given a specific Velocity Factor and dielectric constant.
  • Some participants discuss the relevance of the dielectric constant (Er) in calculations related to Velocity Factor and wavelength.
  • One participant proposes a formula for wavelength involving Velocity Factor and frequency, while others express uncertainty about incorporating Er into the calculations.
  • There is a mention of the relationship between the relative speed of the source and detector affecting observed wavelength.
  • Some participants express confusion about the context of the discussion, particularly regarding whether the signals are transmitted through a cable or in free space.
  • A participant suggests that the Velocity Factor should be calculated as c/sqrt(Er), but questions arise about the validity of this calculation with specific values of Er.
Participants do not reach a consensus on the exact relationship between Velocity Factor, wavelength, and dielectric constant. Multiple viewpoints and uncertainties remain regarding the definitions and calculations involved.
Limitations include unclear definitions of terms, varying interpretations of the context (cable vs. free space), and unresolved mathematical steps in the calculations involving Velocity Factor and dielectric constants.
edieber
is the Velocity Factor is a factor to caculate the length wave(gama) or its only connected to the type of the cabe
Could you try rephrasing the question? Perhaps there are others on the board who speak your native language who will help you translate.
I just want to know the meaning of Velocity Factor and if it influence the calculation of the length wave? :rolleyes:
Your going to have to be a lot clearer and give the context as what you are using is from what I gather the 'velocity factor' is engineering terminlogy referring to the speed of propagation of a signal as a fraction of c, though I could be wrong (and I think you mean wavelength not 'length wave').
do you know if it influence the wavelength? :confused:
Yes, the relative speed of the source and the detector influences the observed wavelength.
what is formula to calculate the wavelength if Velocity Factor is 0.66
and Er=1.2 for example
ou have to be clearer 'cos I'm not exactly sure what you're talking about: what exactly are we delaing with? are we dealing with an electrical signal through a wire?
yes! electrical signal through a wire
You'd do a lot, lot better to post this on the engineering forum, but:
wavelength = velocity factor*(the speed of light in a vacuum/frequency)
where do you take under consideration the Er ?
What is 'Er'?
jcsd said:
What is 'Er'?
Code:
[tex]\epsilon_r[/tex]
dialectrical coefficient
I'll have to say I don't know how you'd go about calcualting or even if you can calculate it from the velcoity factor and the dialectric cooefficient ,though I think your not after the wavelength but the reflection coefficient.
[tex]\lambda_{observed} = \lambda_{source} \sqrt { \frac {1-\frac {v}{c}}{1+\frac {v}{c}}[/tex]
why you don't take under consideration [tex]\epsilon_r[/tex]
the dialectrical element
Because I don't fully understand your question. If you are talking about a transmitter and a receiver that are in relative motion with respect to each other then I presume the signal is propagating through empty space or possibly air whose dielectric constant is very close to 1. It doesn't make sense to me that one end of a cable would be moving relative to the other if that's the medium you are talking about.
I think he's talking about the velocity of signal transmission along a coaxial cable, or possibly a transmission line.
as in for instance
http://www.nr6ca.org/vf.html
If so, the velocity factor should be approximately c/sqrt(Er), where Er is the permitivity of the dielectric material relative to the permitivitty of free space.
as in for instance
Oh, okay! I've never heard it called a "velocity factor."
as in for instance
how come if Er=1.24 put it in the formula c/sqrt(Er) it never will be vf=0.666 for example :confused:
  • · Replies 47 ·
  • · Replies 27 ·
  • · Replies 27 ·
