I don't understand this question
  • Thread starter Thread starter SpatialVacancy
The discussion centers on the uniform electric field between two large, closely spaced parallel plates carrying equal but opposite charges. It is established that when the plates are sufficiently large and close together, the electric field remains nearly constant in strength throughout the gap, except near the edges. This uniformity can be approximated as if the plates are infinite in extent, allowing for simplified calculations of the electric field's behavior in that region.
  • Understanding of electrostatics principles
  • Familiarity with electric field concepts
  • Knowledge of parallel plate capacitor theory
  • Basic mathematical skills for field strength calculations
  • Study the derivation of the electric field between parallel plates
  • Explore the concept of electric field lines and their properties
  • Learn about the effects of edge effects in capacitors
  • Investigate applications of parallel plate capacitors in circuits
This discussion is beneficial for physics students, educators, and anyone interested in understanding electrostatics and electric fields in capacitive systems.
SpatialVacancy
I do not understand this question. Can someone restate it?
Code:
Show why the field between two large but closely spaced parallel
plates carrying equal but opposite charges should be uniform in
the region not too near the edges.
Use any method you can understand and explain.
The idea is that when the plates are very large AND very close to each other then the electric field will be normal to the surfaces and its strength should vary very little in traversing the gap between them - as long as you aren't to close to the edges! Can you see why?
If you were standing between the large plates, then for practical purposes you can approximate it as if the plates have infinite extend.
  • · Replies 31 ·
  • · Replies 26 ·
  • · Replies 58 ·
