Every nonzero vector space can be viewed as a space of functions
This discussion focuses on proving that the mapping Ψ: C(S,F) → V is an isomorphism for a nonzero vector space V over a field F, where S is a basis for V. The user initially struggled to demonstrate that Ψ is onto, particularly for infinite-dimensional cases. However, they concluded that every vector in V can be expressed as a linear combination of a finite number of basis vectors from S, confirming that Ψ indeed maps to all vectors in V, thus establishing the isomorphism.
  • Understanding of vector spaces and their properties
  • Familiarity with linear transformations and isomorphisms
  • Knowledge of finite and infinite-dimensional vector spaces
  • Basic concepts of linear combinations and bases in linear algebra
  • Study the properties of linear transformations in vector spaces
  • Learn about the concept of bases and dimension in vector spaces
  • Explore the relationship between finite and infinite-dimensional vector spaces
  • Investigate maximal linearly independent sets and their implications in linear algebra
Students of linear algebra, mathematicians exploring vector space theory, and anyone interested in understanding the structure of function spaces in relation to vector spaces.
Buri
Let V be a nonzero vector space over a field F, and suppose that S is a bases for V. Let C(S,F) denote the vector space of all functions f ∈ Ω(S,F) (i.e. the set of functions from S to a field F) such that f(s) = 0 for all but a finite number of vectors in S. Let Ψ: C(S,F) → V be defined by Ψ(f) = 0 if f is the zero function, and Ψ(f) = Σ {s ∈ S, f(s) ≠ 0} f(s)s, otherwise. Prove that Ψ is an isomorphism.
The attempt at a solution
Okay, I've already proved that Ψ is linear, that it is 1-1, but I'm having troubles proving that it is onto. Here's what I've done:
I'd like to be able to show that for any v ∈ V there is a f ∈ Ω(S,F) such that Ψ(f) = v. So v = (a1)s1 + (a2)s2 + ... where S = {s1, s2, ...} is a basis for V (I haven't been told whether V is finite or infinite dimensional). However Ψ(f), when f is nonzero, is a linear combination of FINITE number of elements of the basis. I do realize we could write Ψ(f) = f(s1)s1 + f(s2)s2 + ... where some of these will be zero as f is only nonzero at a finite number of them. See if v = (a1)s1 + a2(s2) + ... + (an)sn then I could define f to be f(si) = ai and I would be done. But the problem is that I can't see and can't show that Ψ(f) could ever equal a vector in v which is a linear combination of an infinite number of elements of the basis.
Any help? This isn't homework, I'm taking a look at linear algebra on my own this summer. Thanks a lot!
EDIT: I've figured it out! :)
The vectors in V will be written as a linear combination of FINITE number of vectors of S - this is by definition! I hadn't read a section on Maximal linearly independent sets (the course I'll be taking in the fall skips it) so I hadn't seen this result.
Well, S here is the basis for both vector spaces, i.e., the free vector space on
S has S as its basis, so the two should be isomorphic.
  • · Replies 25 ·
  • · Replies 32 ·
  • · Replies 38 ·
