Levitate a coin using two powerful magnets
  • Context: High School
  • Thread starter Thread starter udaibothra
    Magnets
The discussion explores the feasibility of levitating a coin using two powerful magnets positioned on either side. It considers the theoretical aspects of magnetic attraction and stability, as well as practical implementations involving different types of magnets.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that if two equally strong magnets attract a coin, there could be a point where the forces balance, allowing the coin to levitate.
  • Another participant argues that permanent magnets cannot achieve stable levitation, comparing it to balancing a marble on a knife's edge, indicating that the coin would fall in one direction or another.
  • A different viewpoint mentions that using electromagnets with a feedback control system could stabilize the levitation.
  • It is noted that the material of the coin affects the outcome, with some coins being non-magnetic, while others may be magnetic or conductive, which would require different methods for levitation.
  • One participant points out that levitating a conducting object would involve using an oscillating magnetic field to create a repulsive force rather than an attractive one.
Participants express differing views on the stability of levitation with permanent magnets, with some suggesting it is impossible while others propose alternative methods using electromagnets. The discussion remains unresolved regarding the feasibility of levitating a coin with the described setup.
The discussion highlights limitations related to the types of magnets used and the material properties of the coin, which may affect the levitation process. There are also unresolved questions about the stability of the levitation and the conditions required for it to occur.
udaibothra
Hello Everyone,
I was wondering if you could levitate a coin using two powerful magnets on wither side of the coin? I mean, if the magnets equally attract the coin(provided they are equally strong), there must be a point where the force of attraction from both the magnets is equal and if that point can be found, it must be possible that the coin just stays in air, being equally attracted by the magnets. Or is it that the magnets might cancel out each others forces, and that point might be a null point? Thanks! :)
It's not stable with permanent magnets. You can use electromagnets with a feedback control system to hold it steady.
It's not stable for the same reason you can't balance a marble on the edge of a knife. It will fall one way or the other.
You can do something like this using electromagnets - its the basis of the Maglev system.
Also depends on the coin. I found that US coins are universally non-magnetic, but coins of some other countries are.
Of course, you can still levitate any conducting object, in principle, but then you'd be using oscillating magnetic field, and you'll be repelling the object, rather than attracting it.
  • · Replies 22 ·
  • · Replies 42 ·
