Find the x and y component of vector c
  • Thread starter Thread starter ios
    Component Vector
The problem involves finding the x and y components of a vector c that is perpendicular to vector a and has a specific scalar product with vector b. The vectors a and b are defined in the xy-plane, and the relationship between these vectors is explored through their geometric and algebraic properties.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conditions for vector c to be perpendicular to vector a and the implications of the scalar product with vector b. There is confusion regarding the use of certain ratios and angles in the equations presented, as well as the origin of specific numerical values.
The discussion is ongoing, with participants questioning the validity of the equations used and the rationale behind incorporating certain ratios. There is an exploration of the relationships between the components of the vectors, but no consensus has been reached on the correct approach to solve for the components of vector c.
Participants are navigating through the constraints of the problem, including the requirement for vector c to maintain a perpendicular relationship with vector a and the specified scalar product with vector b. There is uncertainty regarding the definitions and calculations involved in the problem setup.
ios
You are given vectors a = 4.50i-7.00j and b = -3.50i+7.40j. A third vector c lies in the xy-plane. Vector c is perpendicular to vector a and the scalar product of c with b is 10.0.
now i figured that since vector a is in quad 4, then to be perpendicular, vector c would have to be in quad 1 or 3, but I am not sure which one. i got that to find the scalar product, its 10 = -3.5(Xc)+7.4(1.556Yc) & arctan(32.7352)=Xc/1.556Yc. but then i kind of reach a dead end and i can't figure out what to do. the question asks to find the x and y component of vector c.
Can't you solve that system of equations for Xc and Yc?
P.S. what are Xc and Yc, and where did the 32.7352 and the 1.556 come from?
Xc is the x component of vector c, and Yc is the y component of vector c. I'm just not sure if my math was right or not. 32.5372 is the angle if you take tan of 4.5/7. and 1.556 is the ratio of x to y (vector a).
But why does it appear in your equations?
don't i need that for vector c to be perpendicular to vector a?
I get the feeling you're mixing fragments of equations together without really knowing why.
You have (correctly) determined that Xc / Yc = 14/9 (= 1.556).
But why did you put the 1.556 into the two equations
don't i need to maintain that x to y ratio for the angle of vector c to be perpendicular to vector a? i thought that was the only way to keep the angle so that added together, the angle between vector c and vector a equals 90.
Remember that the definition of dot product is:
"The product of the x coordinates plus the product of the y coordinates".
The y coordinates of b and c are 7.40 and Yc respectively. (not 1.556 Yc)
