Solving LC Circuits with Qmax: Deriving Relationship for Q(t)
  • Context: Graduate
  • Thread starter Thread starter eprparadox
    Circuits Lc
The discussion revolves around deriving the relationship for charge Q(t) in an LC circuit, particularly focusing on the application of Kirchhoff's laws and the implications of magnetic flux changes. Participants explore the derivation process, the role of electric fields, and the resulting differential equations.
  • One participant questions the validity of applying Kirchhoff's law in the context of changing magnetic flux, suggesting that the closed loop integral of E dot dl is not zero.
  • Another participant agrees with the concern about Kirchhoff's law and asks for clarification on the derivation process leading to the differential equation.
  • A participant explains their reasoning regarding the electric field in the capacitor and how it affects the signs in the equations, ultimately leading to a negative sign in the differential equation.
  • Another participant emphasizes the importance of correctly defining the charge on the capacitor plates and how that affects the integral and the resulting equations.
  • One participant provides a more straightforward approach using Kirchhoff's laws, presenting a differential equation for the charge in the capacitor without needing to delve into the complexities of the electric field in the inductor.
Participants express differing views on the application of Kirchhoff's laws and the treatment of electric fields in the derivation process. There is no consensus on the best approach to derive the relationship for Q(t), and multiple competing views remain present in the discussion.
Participants highlight the importance of sign conventions and the definitions of charge in their calculations, indicating potential limitations in their reasoning. The discussion also reflects varying levels of comfort with applying Kirchhoff's laws in different contexts within the circuit.
eprparadox
Hey everyone,
So I'm working with this simple LC circuit where the capacitor has been charged to some Qmax. I want to derive the relationship for Q(t) (aside from using the book). But I'm stuck.
The book's derivation uses kirchhoffs law of voltages around a loop. But it seems to me like you can't use that law in this case because the closed loop integral of E dot dl is not zero around the loop. Rather, it now equals the change in magnetic flux in time.
Is this a true statement?
If so, then I now have the closed loop integral of E dot dl = - d/dt(magnetic flux).
And now I want to evaluate the integral on the left side. And the only place where there is an electric field is in the capacitor. But I don't know how to proceed from there to getting the standard second order diff eq. that allows us to solve for Q(t) as a S.H.O. solution.
If I have my circuit set up with the polarities as shown in the attached image, then it seems like I get - Q/C = - LdI/dt. And this will ultimately give me wrong diff eq. I get the -Q/C because the electric field is pointing in the opposite direction of the path I've chosen.
Sorry for the long post. If anyone understood this and can offer some help, that would be greatly appreciated. Thanks.
I didn't post the image!
Good point!
Can you go a bit into details on this? Maybe reading your work may help me understand why you arrive at that equation.
Hey thanks a lot for the response!
So, using the attached image as a reference, there is an electric field that points from the positive terminal to the negative terminal of the capacitor. And this electric field is E = sigma/epsilon.
And I'm going to choose my path for this closed loop integral to be clockwise (which is the direction we assume positive charge moves). So I move this positive charge from the negative terminal (lower potential) to the positive terminal (higher potential) and so now I have my E-field pointing in the opposite direction to my chosen path, dl. This will bring about a negative sign. And if I say the distance between the capacitor plates is d, then E dot dl becomes -sigma/epsilon * d, but this simplifies to Q/C (since sigma is Q/A). So basically I have -Q/C and this is just the voltage across the capacitor and this equals -L*dI/dt.
So the negatives from both sides cancel out and I am left with Q/C = L*dI/dt, which is off by a negative sign for the diff eq. that gives us the proper solution of S.H.O. motion.
I tried to be clear! I hope my train of though made sense. Let me know anywhere where I'm wrong in my logic! Thanks again.
First, I have to say that you shouldn't write the signs (+) and (-) next to the plates, as you know, the sign of each plate changes periodically, especially when you found a subtle point about using Kirchhoff's rule. When you want to do it right, you should do it right from the start to the end. Moreover, when you mention the invalidity of using Kirchhoff's rule, you should forget the term "potential difference" or "electric potential". I'm not sure if electric potential is defined in this case, but leaving it out won't do any harm.
Just my 2 cents :wink:
The integral will be: [tex]\oint\vec{E}\vec{dl}=-Ldi/dt[/tex] if you set the current i moving in the same direction of the path chosen for computing the integral. You are still right at this point.Then you will have: [tex]\oint\vec{E}\vec{dl}=-Q/C[/tex] only if you choose Q as the charge of the upper plate. The sign would change (i.e. [tex]\oint\vec{E}\vec{dl}=Q/C[/tex]) if you chose Q as the charge of the lower plate. Note that the direction to take the integral is still clockwise. If it were anti-clockwise, then Q in [tex]\oint\vec{E}\vec{dl}=-Q/C[/tex] would be the charge of the lower plate.Until now, you have: [tex]-Q/C = -Ldi/dt[/tex]. Since Q is the charge of the upper plate, and the direction of current i is clockwise, i.e. the current i is "going out of" the upper plate or Q, we have: [tex]i=-dQ/dt[/tex]. This equation should make sense, since the current i is going out of the plate Q, i.e. the charges are going out of the plate Q, then Q should decrease, which corresponds to the minus sign in the equation.
Now it goes all the way back to the good old solution, right? :wink:
When you apply Kirchoff laws to an LC circuit, you shouldn't be trying to apply it to inductor wire. You consider an inductor as a simple element in the circuit, whose voltage drop is known.
Kirchoff current law applied to capacitor tells you this.
[tex]\dot{q_C} = I_C[/tex]
Voltage across the two elements is easy.
[tex]V_C=\frac{q_C}{C}[/tex]
[tex]V_I=L\frac{dI_L}{dt}[/tex]
Kirchoff current law applied to the whole circuit.
[tex]I_L=I_C=\dot{q_C}[/tex]
And the voltage law.
[tex]V_C+V_L = 0[/tex]
Or if you expand it in terms of qC.
[tex]\frac{q_C}{C}+L\ddot{q_C}=0[/tex]
And that's a differential equation with a simple solution.
[tex]q_C=Acos(\omega t) + Bsin(\omega t)[/tex]
Where
[tex]\omega=\sqrt{\frac{1}{LC}}[/tex]
There is no need to invent anything more complicated. You could in principle integrate over the field inside the inductor and still get the same result, but you really shouldn't be using Kirchoff's laws at that point anymore. These were invented specifically so that you don't have to do any of this.
Hey, thanks a lot for your response. Things are all clear now. I really appreciate your taking the time to help out.
Take care!
  • · Replies 23 ·
