Thread Closed
Finding the Bases for kernel and range of linear transformation.
Share Thread Thread Tools
Jul28-10, 01:07 AM   #1
How do I find the bases for both the kernel and range of this linear transformation?
Let T: R4 ----> R4 be the linear transformation that takes [1101] and [1011] to [2304] and takes [1110] and [0111] to [3120]
a. Find the bases for both the kernel and the range of this linear transformation.
b. Give and orthonormal basis for the kernel of this transformation
c. Indicate the matrix that would represent T under the standard basis for R4
2. Relevant equations
Gram-Schmidt
u1 = v1
u2 = v2 - (<v,u>/<u,u>)u
3. The attempt at a solution
For part a:
I can find the basis for the kernel but I do not know how to find it for the range.
Basis for Kernel:
Since the transformation takes two vectors to one, I used this property to find out the
basis for the kernel, which is T(u - v) = [1101 -1011] = [0,1,-1,0]
I did the same for the other two vectors which resulted in [1,0,0,-1].
Basis for the Range: ?
For part b:
I took the two basis vectors and used the Gran-Schmidt to find the orthonormal basis for the kernel which is {[tex]\sqrt{}2[/tex]/2 (1,0,0,-1), [tex]\sqrt{}2[/tex]/2(0,1,-1,0)}
for part c: I do not know how to do it. I know how to find a transformation matrix given two transformations that go to different vectors; however, that is not the case here as two vectors transform to the same vector. This happens for two different sets.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jul28-10, 01:37 AM   #2
Mentor
Quote by avister51291 View Post
Gram-Schmidt
u1 = v1
For part a:
Basis for Kernel:
You're being very sloppy here. For a linear transformation T, it must be true that T(u - v) = T(u) - T(v).
So T(u - v) = T([1101] -[1011]) = T[0,1,-1,0]
and T(u) - T(v) = [2 3 0 4] - [2 3 0 4] = [0 0 0 0].
So T[0,1,-1,0] = [0 0 0 0].
Is this what you meant to say?
Do you mean to say that T[1,0,0,-1] = [0 0 0 0]?
From this it appears that the ker(T) is at least dimension 2 and maybe more.
For part b:
Jul28-10, 10:44 AM   #3
Yes, for part A I meant that in order to find the basis for the kernel I would need to do
T(u-v) = T(U) - T(V). The vectors that would go to [0 0 0 0] under the transformation are
[0,1,-1,0] and [1,0,0,-1].
So the basis for the kernel of this transformation is B= {[0,1,-1,0], [1,0,0,-1]}
How would I go about finding the basis for the range and transformation matrix by looking at what I was given?
Jul28-10, 05:02 PM   #4
Mentor
Let's give these vectors some names:
u1 = [1101]
u2 = [1011]
u3 = [1110]
u4 = [0111]
From your previous work, you know that T(u1 - u2) = 0 and that T(u3 - u4) = 0.
IOW, you know that T([01-10]) = 0 and T([100-1]) = 0.
What about T(u1 + u2)? T(u3 + u4)?
Thread Closed
Tags
basis, kernel, matrix, range, transformation
Thread Tools
Similar Threads for: Finding the Bases for kernel and range of linear transformation.
Thread Forum Replies
Finding range and kernel of linear transformation Calculus & Beyond Homework 3
Finding a Linear Transformation with specific domail and range Calculus & Beyond Homework 2
Kernel, Range, Basis (linear algebra) Linear & Abstract Algebra 6
LINEAR ALGEBRA - Describe the kernel of a linear transformation GEOMETRICALLY Calculus & Beyond Homework 6
Finding the kernel and range of a tranformation Calculus & Beyond Homework 11
