Thread Closed
Finding an orthonormal basis of a Hilbert space relative to a lattice of subspaces
Share Thread
Jul30-10, 12:21 AM   #1
I have a Hilbert space H; given a closed subspace U of H let PU denote the orthogonal projection onto U. I also have a lattice L of closed subspaces of H, such that for all U and U' in L, PU and PU' commute. The problem is to find an orthonormal basis B of H, such that for every element b of B and every element U of L, b is an eigenvector of PU (equivalently, b is in U or U).
The obvious thing to do is to apply Zorn's lemma to obtain a maximal orthonormal subset B of H satisfying the above condition, and this part works. For some reason or other, though, I'm having trouble showing that span B = H. If not, then letting W = span B, I need to find a normalized vector v in W such that for every U in L, v is an eigenvector of PU; then B ∪ {v} contradicts the maximality of B. (The following may or may not be helpful: It suffices to consider the case where U contains W.)
The idea I have right now is this: Suppose I could find a one-dimensional subspace V of W such that PV commutes with PU for all U in L, and let v be a normalized vector in V. Then for every U in L, PVPU(v) = PUPV(v) = PU(v), so PU(v) is in V. Since V is 1-dimensional, v is an eigenvector of PU(v), as desired.
The problem is that I have no idea how to choose V. I feel like this should be really easy, but for some reason I'm not seeing it.
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Aug3-10, 04:58 PM   #2
It is impossible, here is a counterexample:
Let your Hilbert space be [tex]L^2([0,1])[/tex], and let you lattice of subspaces is parametrized by [tex]a\in[0,1][/tex], namely
[tex] U_a = \{ f\in L^2([0,1]) : f(x) =0\ \forall x>a\}[/tex]
It is easy to see that the projections [tex]P_{U_a}[/tex] do not have common eigenvectors (because [tex]\displaystyle\cap_{a\in (0,1)}U_a =\varnothing[/tex])
Aug4-10, 01:26 AM   #3
Interesting, so it's impossible even if H is separable. Thanks.
I was more generally considering normal operators, rather than projections (although the case of normal operators can be reduced to the above problem). Wikipedia says it works if the operators are compact, or if one of them is compact and injective. I'll have to check if this is the case for the application I had in mind.
Thread Closed
Similar discussions for: Finding an orthonormal basis of a Hilbert space relative to a lattice of subspaces
Thread Forum Replies
Finding an orthonormal basis Calculus & Beyond Homework 12
Linear Algebra Finding Basis for space. Calculus & Beyond Homework 4
Finding a basis of a vector space Calculus & Beyond Homework 10
Orthonormal basis Calculus & Beyond Homework 7
complete basis for quantum oscillator Hilbert space Quantum Physics 43
