Is the trivial solution a unique solution?
  • Context: Undergrad
  • Thread starter Thread starter darthxepher
The discussion centers around the uniqueness of the trivial solution in the context of linear equations of the form Ax = b. Participants explore conditions under which the trivial solution is considered unique, particularly focusing on the cases when b is zero or non-zero, and the implications of matrix A being invertible.
  • Some participants assert that if the only solution to Ax = b is the trivial solution, then it is considered unique by definition.
  • Others clarify that if b is non-zero, there cannot be a trivial solution, while if b is zero and A is invertible, then x=0 is indeed the unique solution.
  • One participant questions the relevance of least squares approximation to the topic of unique solutions, suggesting that approximations exist regardless of their quality.
There is no consensus on the relationship between trivial solutions and uniqueness, as participants present differing views on the conditions under which a trivial solution can be considered unique.
The discussion does not resolve the implications of non-zero b on the existence of trivial solutions, nor does it clarify the connection between least squares approximation and unique solutions.
darthxepher
If the only solution to Ax = b is the trivial solution, then is that solution considered unique?
If b is non-zero, there is no trivial solution.
If b is zero, and A is invertible, then yes, x=0 is the unique solution
Do you know how to tell if the least squares approximation exists?
If it's the only solution, then by definition it's unique.
It doesn't matter whether it is trivial or not, "only solution"= "unique solution".
I have no idea what "Do you know how to tell if the least squares approximation exists?" has to do with "unique solutions" but approximations, whether good or bad, always exist.
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 33 ·
