Distance Formula: Find JK Distance to Nearest Tenth
  • Context: High School
  • Thread starter Thread starter xowe
    Formula
The discussion revolves around calculating the distance between two points, J(2,-1) and K(2,5), using the distance formula. The focus is on confirming the correctness of the calculations and understanding the concept behind the distance between points in a Cartesian plane.
  • Homework-related
  • One participant presents their calculation of the distance using the formula, expressing confusion about the correctness of their approach.
  • Another participant confirms that the solution provided is correct.
  • A third participant notes that since the x-coordinates are the same, the distance can be simplified to the difference between the y-coordinates, which is 5 - (-1) = 6.
  • The original poster acknowledges this simpler approach and expresses appreciation for the insights shared.
Participants generally agree on the correctness of the distance calculation, with no significant disagreement noted. However, there is a recognition of different approaches to arrive at the same result.
xowe
Yah, easy I know, but I got a little confused. Okay, here's the problem:
Find the distance between the points to the nearest tenth. J(2,-1) K(2,5) Here's what I did. d=√(2-2)^2+(5-(-1)^2 (the ^2 means squared) √(2-2)^2=0 so I'm left with √(5-(-1)^2= √(6)^2= √36=6 Ok, so how did I do? I wasn't sure if what I did was right, I think so, but I just needed to make sure. Thanks.
Mathematics news on Phys.org
Your solution is correct.
In fact, in that case, since the x coordinates of (2,-1) and (2,5) are the same so the distance is just the distance between -1 and 5 on a number line: 5-(-1)= 6.
Oh, yah I never thought about that. Heh, that would have saved some time, I'll remember that! Thanks to both of you.
  • · Replies 42 ·
  • · Replies 41 ·
  • · Replies 33 ·
