Significance of the Hat Symbol in Quantum Mechanics and Classical Kinematics
  • Context: Undergrad
  • Thread starter Thread starter amorrow
The discussion focuses on the significance of the hat symbol in quantum mechanics and classical kinematics, particularly regarding its use with the Hamiltonian and momentum symbols. Participants explore the implications of the notation in different contexts, including the Schrödinger equation.
  • Some participants propose that the hat over the Hamiltonian indicates it is an operator, while the hat over momentum signifies a unit vector.
  • Others argue that the hat over momentum also indicates it is an operator, as seen in expressions like \(\hat{p} = -i\hbar\frac{d}{dx}\).
  • A later reply questions the consistency of notation in different texts, noting that some authors use alternative symbols for the momentum operator.
  • Participants mention that the use of the hat symbol can vary between quantum mechanics and classical kinematics, with the hat indicating an operator in quantum contexts and a unit vector in classical contexts.
Participants express differing views on the meaning of the hat symbol, particularly regarding its application to momentum. There is no consensus on a single interpretation, and the discussion remains unresolved.
Limitations include the potential for varying definitions of the hat symbol across different texts and contexts, as well as the inconsistency noted in sources like Wikipedia.
amorrow
This is a beginner's question: what does that hat about the H (Hamiltonian) symbol signify? One often sees it in the Schrödinger equation and a few other symbols such as the p of momentum.
Two different things is the answer. The caret above the Hamiltonian tells you that it's an operator, the caret above a momentum vector tells you that this specific vector is a unit vector.
Are you sure about that last one? :smile: [itex]\hat p=-i\hbar\frac{d}{dx}[/itex] is certainly an operator. The hat is there because the author wants to be able to write things like
[tex]\hat p e^{ipx/\hbar}=pe^{ipx/\hbar}[/tex]
Amorrow, a lot of books don't use the "hat" notation. For example, Weinberg writes this [itex]\hat p[/itex] as P instead, and Sakurai writes it as p. Sakurai writes p' for what I called p above.
Yes, if the the momentum is the momentum operator, then the caret means it's an operator. Tbh actually thinking about it, it's far more likely that the symbol amorrow saw was meant to represent the momentum operator.
Yes, I was looking at the Wikipedia entry on momentum operator, etc. Their use of the caret/hat is somewhat inconsistent.
Yep, in a quantum mechanical setting it's going to mean the momentum operator. In a classical kinematic setting it'd probably mean a momentum unit vector.
  • · Replies 0 ·
  • · Replies 116 ·
10K
