Which magnet configuration will produce a faster propelled ball?
  • Context: Undergrad
  • Thread starter Thread starter Experimenter
    Magnets
The discussion revolves around an experiment designed to compare two configurations of magnets and their effect on the propulsion speed of a steel ball. The focus is on the theoretical implications of the configurations and the assumptions involved in measuring the impact and resulting motion of the balls. The scope includes experimental design and the physics of magnetism and motion.
  • Experimental/applied
  • The experimenter describes two configurations of magnets and a steel ball, questioning which configuration will produce a faster propelled ball.
  • Some participants express concerns about the adequacy of the information provided to predict outcomes.
  • There is a debate about the assumption that the impact force of the ball hitting the magnets is identical, with some participants suggesting this is problematic.
  • One participant proposes adjusting the starting distance of the ball to ensure equal impact force in both configurations.
  • Another participant raises the issue of energy transfer and initial velocity, questioning the role of momentum versus force in the collision.
  • Concerns are raised about the effects of eddy currents on the steel ball's motion as it rolls away from the magnets.
  • Suggestions for measuring the initial velocity of the departing ball include using Doppler effect methods or stroboscopic techniques.
Participants do not reach a consensus on several key assumptions, particularly regarding the impact force and the effects of the magnetic field on the ball's motion. Multiple competing views remain regarding the methodology and theoretical implications of the experiment.
Limitations include the need for clearer definitions of terms like "impact force" and "initial velocity," as well as the potential influence of external factors such as eddy currents on the results.
Experimenter
I am building a little experiment to demonstrate the impact of metal objects. It consists of the following two configurations:
Magnets used are grade N38 NdFeB rare Earth magnets.
##RM## - Cylindrical magnet that is 1 1/2" long x 1/2" diameter laid lengthwise
CM - 1/2" cube magnet
B - 1/2" diameter steel ball
Configuration 1:
##RM##-B-B-B
Configuration 2:
CM-B-B-B
A ball will be rolled to impact with the left side as the magnet draws it in. In theory, the impact should be transferred to the right most ball to the right of the magnet, causing it to disconnect from the group of balls to its left and roll to the right. The question is: Which of the two configurations will produce a faster propelled ball leaving the system on the right hand side. Assume that the impact force of the ball hitting the left hand side of each respective magnet is identical.
Thanks
The Experimenter
Some assumptions
I should also add that the magnets are secured by paper tape so as not to move towards the ball being rolled from the left and that motion is restricted (by a track for example) to be only in the left and right directions.
Experimenter
The dashes indicate touching surfaces
Just so there is no confusion
You have presented nowhere near enough information for any of us to have any idea what will happen.
- Warren
I think this assumption is problematic. No way to really ensure this, IMO...
Still waiting for my magnets I just ordered... I do know one possibility though, they shatter!
- Warren
What information is missing? I thought I presented all physical characteristics.
Thanks
One way to do this is by starting with a ball at rest to the left of the magnet. The starting distance from the magnet can be adjusted so that the force of impact is equal in both scenarios.
Thanks
Experimenter
Shattering and chipping is a real problem. One way I thought of to minimize this possibility is to use a tiny steel washer to spread the force of impact from a single point on the face of the cylinder or cube, to a small circular area.
Can it? I doubt that.
You're talking about collison here, so force may not be the proper quantity at all. Momentum might.
I am referred to the energy transfer to the right most sphere and the initial velocity with which it starts rolling to the right.
That ball is made of steel, right? Plus, it's in the magnetic field, isn't it? So it will be slowed down while rolling away. By many effects, one of which is eddy currents. So how do you want to determine its initial velocity?
I only need the initial velocity at departure time (i.e. the time when it separates from the ball next to it.
Experimenter
I guess the most exact method to measure this would be one that uses Doppler effect - like when the police measure the speed of a car.
Maybe some stroboscopic method, or even video, will do as well.
  • · Replies 25 ·
