| Thread Closed |
Faraday cage problem with RFiD |
Share Thread | Thread Tools |
| Aug4-10, 08:13 AM | #1 |
I'm working in a tracking solution based on RFiD, that consists on tags without any type of battery or power source. When the antenna generates the signal in the correct frequency, an induction process occur in the tag, generating a response to the antenna (containing the tag's id number).
The problem is: we need to place tags inside of an metal tripod (aluminium or iron, about 5mm of thickness), that has a few holes (1 cm each one). The frequency used is 900mhz. I believe that: - Could be a Faraday cage. The metal of the tripod is blocking the antenna's eletric field, so the tag isn't receiving the necessary amount of power to answer. - The metal is distorting the frequency, so the tag cannot receive any signal. I've some success using a piece of wire, connected to the metal in the tag and passing it to outside by one of the holes (like an antenna). If the wire touches the metal surface (it's properly isolated), the signal is interrupted. It's possible to pass a radiofrequency trough the cage? Using a frequency of 120khz or 13.5mhz could help (there are another tags with those frequencies. The 120khz one has a bad read range)? How can I calculate the effects of the cage (I've read that is calculated by the Gauss law)? I need some help to calculate it's effects on the radio signal frequency and intensity. |
| Aug4-10, 09:00 AM | #2 |
I think you need to look at the 'skin depth' which is the distance EM waves can penetrate a conductor. I believe it decreases with frequency, so using a lower frequency may help penetrate the shielding. The 'optical' effects of the holes and the geometry of the metal will be much more complex to calculate...
| Aug4-10, 09:03 AM | #3 |
Best bet for this kind of work is computational electromagnetic simulations. For real applications, you are interested in detailed properties like read distance which really needs a proper solver to give you an accurate answer. The holes are not going to channel much radiation as 1 cm is too small to guide waves in any frequency desirable for RFID. For the most part it is going to look like a solid piece of conductor at such low frequencies and 5 mm is pretty thick too. Lower frequency will help as the skin depth will be much deeper and you may have a chance of penetrating the conductor. You could always do a back of the envelope calculation to see what kind of attenuation you can expect and use that as a rough estimate to find your read distance. Of course how you mount the tag matters a lot here since you are mounting it to a conductor. Mounting tags on a conductor is a whole other problem in and of itself.
| Aug4-10, 09:48 AM | #4 |
Ok, I've searched about skin depth and found this:
[tex]\delta=\sqrt{{2\rho }\over{\omega\mu}}[/tex] I've applied it to 900mhz, 13.5mhz and 125khz. The results weren't what I was expecting: Using (aluminium): [tex]\rho[/tex]: 2.82×10−8 [tex]\omega[/tex]: 2pi x frequency [tex]\mu[/tex]: 1.2566650×10−6 The results: 900mhz: 2.81721... x 10-6 m 13.5mhz: 0.0000230024 m 125khz: 0.000239048 m These calculations are correct? If it's indeed correct, I think that will be very difficult to penetrate metal with that radio frequencies. |
| Aug4-10, 11:09 AM | #5 |
When I worked on a project to put Remote Terminal Units in remote areas of Alaska, the specifications required a stainless steel box for the equipment. (Apparently, in remote areas, people will shoot at anything.) When the equipment arrived, the local engineer called and asked if the radio antenna had to be on the outside of the box.
The answer is Yes. The antenna has to be outside the Faraday cage for electromagnetic frequencies normally used for radio communications, including RFID. Why does the tripod have to be entirely metal? Are you tracking tripods? |
| Aug4-10, 11:35 AM | #6 |
| Aug4-10, 11:42 AM | #7 |
| Aug4-10, 11:46 AM | #8 |
| Aug4-10, 01:55 PM | #9 |
Possible solutions: - 3 tags per tripod, one by leg, with the same ID. That'll improve readings and reduce problems to detect tags. - Using HF tags (13.5mhz), less sensitive to metal. These solutions could work well? With one tag (900mhz), I'm having 30cm of read range. The ideal situation would be an improvement to a 2 m read range. |
| Aug4-10, 03:40 PM | #10 |
| Aug5-10, 07:33 AM | #11 |
Just a question. Could be possible to connect the antenna of the tag (using a wire or other thing) to the metal structure and use it like a big antenna? If I put the tag inside of the tripod, it's not possible to read it. But, holding it with my hand in the same position, it's possible to read it. I'm starting to believe that in this case it used my body as antenna. If I could do that with the tripod, maybe I could get some reads.
We've two possibilities to track the items: - RFID antennas all over the building. Tha tags would be monitored all the time, and an alarm would be activated if one tag dissapears. - RFID antennas in doors, windows and other exits. The items wouldn't be monitored, but the alarm would be activated if an item exits the building without properly authorization. Another advantage is that we would't have to read a lot of items togheter, it would be one by one. It's possible to read it, but the range is limited to 50cm (I'm improving it changing the position of the wire). The idea is to use 3 tags (with 3 wires on them), one by leg, all with the same ID, and read it with more antennas. I think that this could work well with 13.5 mhz (medium range, less problems with metal) and using the second strategy that I described above. Putting the tags outside of the tripod is a solution. There are tags designed to work over metal. We could isolate normal tags to, using a layer between the tag and the metal, giving to it the necessary distance. Actually, we had similar problems using tags to track racing times (running). Each competitor had a tag attached under over the clothes. We had to isolate the tags, because the contact with the skin caused problems to read the tags. |
| Aug5-10, 09:55 PM | #12 |
These are questions that would be best posed to the RFID tag manufacturer. When a tag is designed, the antenna on the tag is designed under certain assumptions about how it will be mounted. In addition, it is tuned to couple efficiently at the desired frequency and tuned to have a matching impedance with the RFID chip for efficient transference of power. Adding a wire to the antenna changes the antenna's impedance and will adversely affect the efficiency of the tag. These kinds of questions and such should be something that the manufacturer can answer for you. I don't think we can give you very detailed answers without knowing intimately the tags that are being used, the manner in which you need to use them and the performance constraints you are working under. Sure you can run a wire off of the tag to try and pick up a signal but I can't say if that will work well enough for your purposes. Electrically isolating the tag and then shorting the antenna to the surface of the tripod. Sure, that might work, but again it is using the tag in a manner that it isn't designed for and I can't say if it would work to your satisfaction. It could, but I can only say that its performance should be worse than if the tag was attached in accordance to manufacturer's specifications.
| Aug6-10, 08:05 AM | #13 |
Unfortunately, with the tag placed inside metal, an external antenna is our only choice. I'll test som other possibilities, like active tags (more range and don't depend of the antenna power, because they already have a battery integrated) and more powerfull antennas. |
| Thread Closed |
| Tags |
| 900mhz, faraday cage, gauss law, rfid |
| Thread Tools | |
Similar Threads for: Faraday cage problem with RFiD
| Faraday cage ? | General Physics | 5 | ||
| Faraday Cage | Introductory Physics Homework | 6 | ||
| [SOLVED] Faraday cage problem | General Physics | 9 | ||
| Faraday cage | Classical Physics | 14 | ||
| Faraday cage | General Physics | 3 | ||
