Linear algebra ordinary differential equations
The discussion revolves around a problem related to linear algebra and ordinary differential equations, specifically focusing on demonstrating that a certain set V is a vector space based on given conditions.
  • Participants express uncertainty about how to approach the problem and seek guidance on demonstrating that V is a vector space. Some question the clarity of the problem statement and discuss the implications of the given conditions.
There is ongoing exploration of the problem, with participants offering hints and discussing the necessary steps to show that V is a vector space. Some participants are clarifying their understanding of the definitions and properties involved.
There are indications of potential typographical issues in the problem statement, leading to confusion about what is required. Participants are navigating these uncertainties while attempting to derive the necessary conclusions.
SpiffyEh
I attached the problem in a picture, I'm not so good at making it show correctly on here.
I'm really unsure of what to do with this problem. I don't know where to start. Can someone please try to guide me through it so I understand? Thank you
Either you chopped off part of the problem or the typesetters of your book did. What you've quoted doesn't tell you what they want you to show about V. I suspect they want you to show V is a vector space. Does that help?
Thats all that was given for that problem. I really don't know what to do
If that's all there is then the book is typographically flawed. That's not even a question. It ends with a ',' where the question ought to be. You have two options i) you can complain about it and try to get out of trying to solve it or ii) you can guess what the problem should be (which is pretty obvious from the hint) and try to show V is a vector space.
well, I don't think I'm going to get out of it. It was typed by the professor, his questions tend to be confusing. I think ii would be my own option. How would I go about showing V is a vector space?
Use the hint. Show if L=0 and L[v]=0 then L[c1*u+c2*v]=0 where c1 and c2 are constants.
I don't know how to do that, that's why I'm having issues with the problem.
That's not good. Do you see why if L[y]=0 then L[c*y]=0, where c is a constant? Can't you factor a constant out of all of the derivatives?
I understand that part about how I can factor things out but I don't understand how to show that u,v are in V so that I can show the part with the constants.
You don't know why L[u+v]=L+L[v]? If D is one your derivatives isn't D[u+v]=D+D[v]??
I guess I was reading it wrong. I thought I had to prove that u,v are in V but since they are L = 0 amd L[v] = 0 so I can split it up like that and bring out the constants. I understand how it can be split up. But does the hint actually prove the point of the problem? Or is it too unclear to see?
You are given u and v are in V. That means L=0 and L[v]=0. If you are clear on why L[c1*u+c2*v]=0 meaning c1*u+c2*v is also in V then that's the whole problem. It means V is a vector space.
  • · Replies 27 ·
