Surge Protector - strange reaction to light sources?
The discussion centers on the unusual behavior of indicator lights in surge protectors, specifically how they react to light sources. The phenomenon is attributed to Neon lamps, which, as they age, experience an increase in ionization threshold voltage. This allows external light to provide enough energy to lower the threshold, causing the lamps to flicker or illuminate when exposed to light. The typical lifespan of Neon lamps ranges from 2000 to 25000 hours, with a noted decline in performance correlating with increased current.
  • Understanding of Neon lamp operation and characteristics
  • Basic knowledge of electrical circuits and voltage thresholds
  • Familiarity with surge protectors and their components
  • Awareness of quality control issues in electronic devices
  • Research the aging process of Neon lamps and their failure modes
  • Learn about voltage threshold concepts in gas discharge lamps
  • Investigate quality control standards for electronic components
  • Explore alternatives to Neon lamps in surge protector designs
Electronics enthusiasts, electrical engineers, and anyone involved in the design or maintenance of surge protectors and lighting systems.
cf879
Surge Protector -- strange reaction to light sources?
We have 2 power strips in our home in which the indicator lights both react to a light source in the following manner: during the day (in the presence of sunlight) the indicator lights shine red with a small flicker every now and then. In the dark, the indicator lights are off unless a light is shone on them, say from a flashlight etc. whereupon they light up red. When the flashlight or other light source is turned off or covered, they go off again. What in the world could cause the indicator lights to react in such a manner?
That is typical of Neon lamps at their end-of-life. As they age their ionization threshold voltage increases. The external light adds a little bit of energy to the gas, lowering the threshold voltage.
This can also be demonstrated with new Neon lamps by applying a voltage just below threshold and then shining a bright light on them.
p.s. Typical Neon lamp lifetime is 2000+ to perhaps 25000 hours and decreases with increased current. I have about a dozen outlet strips here with about 20000 hours on them. One lamp has failed and 8 others are very dim. Quality control seems to be lacking.
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 16 ·
9K
