Opposing forces but opposite travel = no work?
The discussion revolves around the concept of work in physics, particularly in the context of two objects experiencing opposing forces while traveling in opposite directions. Participants explore the definitions and implications of work, displacement, and the conditions under which work is done or not done.
  • Debate/contested, Conceptual clarification, Technical explanation
  • One participant questions whether two objects with opposing forces can travel in opposite directions without doing work, indicating a basic understanding of physics.
  • Another participant explains that work is defined as a force applied over a net distance (displacement), suggesting that if two boxes are pushed to their starting positions, the overall work done is zero.
  • A different participant challenges this explanation, asserting that work is a force applied over a distance rather than a net distance, emphasizing the importance of considering non-conservative forces like friction.
  • Another participant states that both boxes in the diagram are doing work, implying that the direction of forces does not negate the work done.
  • One participant raises a question about the mechanical possibility of stopping both boxes from doing work, indicating an interest in practical applications of the concepts discussed.
Participants express differing views on the definition of work and the conditions under which it is done. There is no consensus on the interpretation of work in the context presented, and multiple competing views remain unresolved.
The discussion highlights potential ambiguities in the definitions of work and displacement, particularly in relation to conservative and non-conservative forces. The implications of friction and the mechanical aspects of the scenario are also noted but not fully resolved.
CountFleet
Hi, This is something I was wondering about. Can two objects with opposing forces travel in opposite directions without any work(minus friction)? I made a drawing in pdf format to demonstrate what I'm trying to say. My understanding of physics is pretty elementary so I apologize if this is a stupid question.
Work is equal to a force applied over a net distance (aka displacement) . Net distance is the difference between your starting and ending point. So if you push a box from point A to point B, and then push it back from point B to point A, no work will be done.
In your diagram, for part 1, it looks like the first box is being pushed to the right by a force pointed to the right, so positive work is being done on that box. The second box is being pushed to the left by a force pointed to the left, so the work being done on that box is also positive. It doesn't matter if the boxes are going in different directions, they are both being moved with positive work.
however, in your second part, it looks like you push the boxes back to their starting positions, so the overall work for the first and second part would be zero since the boxes don't have a change in displacement.
This is incorrect. Work is a force applied over a distance, NOT a force applied over a net distance or displacement. If your force is conservative then the difference is moot, but in the case of friction where the force is not conservative then the difference is very important.
In your diagram both boxes are DOING work.
I was wondering if it was mechanically possible to stop both boxes from doing work?
  • · Replies 75 ·
  • · Replies 54 ·
  • · Replies 19 ·
  • · Replies 40 ·
