Finding Error Bounds for Simpson's Method in Approximate Integration
This discussion focuses on finding error bounds for Simpson's Method in the context of approximating the integral \(\int_{0}^{1}\cos(x^2)dx\) with an error threshold of less than 0.001. The user derived the fourth derivative \(f^4(x)=48x^2\sin(x^2)-12\cos(x^2)+16x^4\cos(x^2)\) and attempted to evaluate the concavity using the sixth derivative \(f^6(x)=720x^2\cos(x^2)-480x^4\sin(x^2)-64x^6\cos(x^2)+120\sin(x^2)\). The discussion concludes that finding an upper bound for the maximum of the fourth derivative is sufficient, and evaluating derivatives at other points can simplify the process of determining concavity.
  • Understanding of Simpson's Method for numerical integration
  • Knowledge of calculus, specifically derivatives and concavity
  • Familiarity with Taylor series expansions
  • Ability to analyze functions and their behavior over intervals
  • Study the properties of Simpson's Method and its error analysis
  • Learn how to compute higher-order derivatives of functions
  • Explore techniques for finding bounds on derivatives
  • Investigate numerical methods for approximating integrals with specified error tolerances
Students and professionals in mathematics, particularly those studying numerical analysis, calculus, and approximation methods, will benefit from this discussion.
Telemachus
Use the Simpson method to estimate [tex]\displaystyle\int_{0}^{1}\cos(x^2)dx[/tex] with an approximation error less than 0.001.
Well, I have a problem. Actually I'm looking for a bound for the error of approximate method integration by using Simpson's method.
I have to bring [tex]\displaystyle\int_{0}^{1}\cos(x^2)dx[/tex] with an error less than 0.001.
I started looking for the fourth order derivative, and got:
[tex]f^4(x)=48x^2\sin(x^2)-12\cos(x^2)+16x^4\cos(x^2)[/tex]
Now, I have to find a bound K for this derivative in the interval [0,1]. What I did do was watch for if they had maximum and minimum on the interval, then calculate the derivative of order five:
[tex]f^5(x)\in{[0,1]}\Rightarrow{f^5(x)=0\Longleftrightarrow{x=0}}[/tex]
From here I did was ask:
If [tex]f^5(x)\in{[0,1]}\Rightarrow{f^5(x)=0\Longleftrightarrow{x=0}}[/tex]
So here I know is that zero is a maximum or minimum. Then I wanted to look for on the concavity of the curve, and I thought the easiest thing would be to look at the sixth derivative, to know how it would behave the fourth derivative of the original function.
[tex]f^6(x)=720x^2\cos(x^2)-480x^4\sen(x^2)-64x^6\cos(x^2)+120\sen(x^2)[/tex]
The problem is that when evaluated
[tex]f^6(0)=120\sen(0^2)=0[/tex]
So, I get zero the derivative sixth, and I do not say whether it is concave upwards or downwards is concave.
What should I do? there may be a less cumbersome to work this, if so I would know.
Greetings.
You could just plot the function and see it hits a maximum on that interval at x=1. Alternately, you can use arguments like x2sin x2≤x2 to find an upper bound for the function. In these types of problems, it's usually not terribly important to find the actual maximum; an upper bound for the maximum is good enough.
I complicated it too much. Just by evaluating the 6th derivative in any other point of the interval I could get the concavity of the curve. An other way was just seeing for the value of the 5th derivative, as the concavity changes only in zero then I would know if it creases or decreases.
Bye, and thanks.
  • · Replies 23 ·
