Optics thought experiment and 2nd law of thermodynamics
The discussion revolves around a thought experiment involving a closed isolated system with two rooms separated by a window made of materials with different refractive indices. Participants explore the implications of this setup on the second law of thermodynamics, particularly regarding energy transfer and temperature changes between the two rooms.
  • One participant describes a scenario where Alice and Bob radiate electromagnetic waves, suggesting that more radiation is transmitted from Alice's room to Bob's room, potentially leading to a temperature imbalance.
  • Another participant challenges the initial calculation, comparing it to one-way mirrors and suggesting that the reasoning may be flawed.
  • Andy references historical calculations by Lord Rayleigh and argues that a gradient of refractive indices allows more light through in one direction, raising questions about the validity of the second law of thermodynamics in this context.
  • Some participants express confusion about how the scenario could violate the second law, questioning the generation of order and the implications of energy transfer between the two rooms.
  • There is a discussion about the transmission of energy versus field amplitude, with references to Fresnel's equations and the symmetry of power transmission.
  • One participant points out that the original scenario seems to imply a cold room could radiate into a hot room without reciprocal energy transfer, which would contradict thermodynamic principles.
  • Another participant suggests that calculating the transmission for multiple layers of materials is complex and requires careful consideration of reflections and interference effects.
  • There is a call for further calculations to clarify the situation, with some participants expressing willingness to explore the problem more deeply.
Participants do not reach a consensus on the implications of the thought experiment. While some challenge the initial assumptions and calculations, others defend the idea that the second law of thermodynamics may not be violated. The discussion remains unresolved with competing viewpoints on energy transfer and thermodynamic principles.
Participants note the complexity of calculating transmission through multiple layers of materials and the need to consider various factors such as angle, polarization, and temperature of the window. There are indications that some assumptions may be missing or that the simplifications in deriving Fresnel's Laws could lead to misunderstandings.
theDoc
Imagine a closed isolated system consisting of 2 rooms separated by a window. The window is built with one layer of material that has refractive index 1.5 and one layer of material that has refractive index 2, for a wide range of wavelenghts (say 1 [tex]\mu[/tex] m - 50 [tex]\mu[/tex] m), and low absorption. The side with lower refractive index is in room A, the side with higher refractive index is in room B. Alice is standing in room A and Bob is standing in room B.
Alice and Bob radiate electromagnetic waves with power [tex]\sigma A T^4[/tex] (Stefan–Boltzmann law) with wavelengths almost entirely in the range 1 [tex]\mu[/tex] m - 50 [tex]\mu[/tex] m (Planck's law). An easy calculation using Fresnel equations shows that more radiation is transmitted through the window from room A to room B than from room B to room A. So Alice should get colder and Bob warmer. Where is the mistake?
Science news on Phys.org
Andy: It's been calculated by Lord Rayleigh in 1880
http://www.nature.com/nphoton/journal/v1/n3/full/nphoton.2007.26.html
and the calculation is really straightforward. The formulas are in http://en.wikipedia.org/wiki/Fresnel_equations
It is well known that a gradient of increasing refractive indices let's more light through than
going directly to a high refractive index.
One-way mirrors have no built-in asymmetry, and that is the reason why they are not real one-way mirrors.
Real one-way mirrors might be impossible to build because they would contradict the 2nd law of thermodynamics (which has never been done). For the same reason: either 1) my experiment doesn't work or 2) the 2nd law of thermodynamics is not always true.
I was hoping for an answer other than it's number 1 because it's not number 2.
Forgive me, I am a little slow...
How does this violate the 2nd law?
Because it generates order - and you could put a stirling engine between the two rooms and generate free energy for ever.
Free energy? It requires the Alice and Bob to radiate though. I could use that radiation directly and do work.
Also, it generates order? So the entropy of the two rooms, alice and bob after radiating is lower than the entropy of the two rooms, alice and bob before radiating? Intuitively I would think the opposite...
For those who are shaky on what's being described: Fresnel's Equations describe the transmission (or reflection) of EM radiation between materials of different refractive indices, as a function of angle and polarization. For example, the transmission of a beam perpendicular to the interface is predicted to be
[tex]\frac{2n_1}{n_1+n_2}[/tex]
when moving from material 1 to 2 and
[tex]\frac{2n_2}{n_1+n_2}[/tex]
when moving from material 2 to 1. I believe theDoc is asking essentially why a temperature difference wouldn't develop between two transparent materials (with difference refractive indices) that were originally at the same temperature. The difference would be sustained by this imbalance in energy transfer.
I am also interested in hearing the resolution. Perhaps a junction is created, analogous to the PN junction in electronics, where thermal conduction balances the asymmetry? Or perhaps one of the simplifications involved in deriving Fresnel's Laws is leading to an apparent paradox? I don't know.
Ah- I see.
The question can be resolved by considering, not the transmission of the field amplitude, but the transmission of *energy* (intensity or power), this is given by (for normal incidence):
T = t^2 *(n_i/n_t)
http://www.inyourfacefotos.com/fresnel.htm
The power transmission is symmetric: there is no imbalance in energy transfer.
Andy Resnick said:
Ah- I see.
T = t^2 *(n_i/n_t)
I don't follow this. T is the power transmission? And t the field? The link you posted seems to say that T = t^2, which is what I would expect...
T is the transmission of the intensity, 't' the transmission of the field.
That's not what the link says. The same formula is written on the wiki page (halfway down) as well.
Edit: on the link I posted, the text just above the equation is correct. The equation itself appears to be misprinted.
Im still confused...
I don't see the discrepancy here. Could somebody walk me through this. So two people emit EM radiation, and one room gets hotter than the other. So what? Thats not order being created, that doesn't violate the second law. If I put two light bulbs in two rooms and turn them on, one room gets hotter than the other - but entropy has still increased.
The OP invented a scenario where it appears that a cold room could radiate into a hot room but not vice-versa, thus making the cold room colder. This would violate the second law of thermodynamics.
I showed that the transfer of energy is not unidirectional: the cold room and hot room radiate into each other equally, which warms the cold room in accordance with the second law.
None of these links seem to talk about the issue at hand: the net transmission of light going in one direction vs. in the reverse direction. I could only see the abstract for the Nature article, but it discusses the graded index case, i.e. a continuous change in n. But we are talking about discrete changes in the index, from 1 to 1.5 to 2 to 1.
Calculating the transmission for multiple layers is rather tricky, as you need to consider multiple reflections within the two materials even if you are neglecting interference effects. To really settle the matter, somebody will have to do the calculation for the OP's example:
n=1 | n=1.5 | n=2 | n=1
If I can find the time this weekend, I may try to produce actual numbers for this example. But others should feel free to jump in and do it, as I am not making any promises here.
According to wikipedia, the fraction of power that is transmitted doesn't depend on which side the radiation is coming from:
[tex]1-\left(\frac{n_1-n_2}{n_1+n_2}\right) ^2[/tex]
(Would the OP detail exactly how they obtain equations which say otherwise? Strictly we should be considering extra details of the situation, like integrating over all directions and polarisations, and accounting for the temperature of the window, but I won't bother before I see that there's any paradox to resolve in the first place.. I see now, this is also what Andy was referring to.)
Andy Resnick said:
Ah- I see.
T = t^2 *(n_i/n_t)
Makes sense, thanks!
you guys are right, my mistake: the transmission is symmetric.
It's not so simple to build something with asymmetric transmission, but maybe possible:
http://arxiv.org/abs/1005.1970
  • · Replies 152 ·
12K
  • · Replies 43 ·
  • · Replies 46 ·
