At what time will runner B catch up with runner A?
  • Thread starter Thread starter JohnQ
    Time
The discussion centers around a problem involving two runners, A and B, with different speeds and start times. The original poster seeks to determine when runner B will catch up to runner A, given their respective speeds of 3.0 m/s and 4.0 m/s, and the fact that runner B starts 5 minutes later.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between the time each runner has been running and their respective distances. Some suggest using linear equations to find the point of intersection, while others question the setup and calculations presented by the original poster.
There is an ongoing exchange of ideas, with some participants providing hints and guidance without revealing solutions. Multiple interpretations of the problem are being explored, particularly regarding the equations and the correct use of time and distance relationships.
Participants note the importance of converting time from minutes to seconds and emphasize that the distance traveled by both runners must be equal at the point of catch-up. There is also mention of potential confusion regarding units of measurement and the need for clarity in the equations used.
JohnQ
Runner A, who runs with an average speed of 3.0 m/s, starts out at 3:00 P.M. Runner B, who runs with an average speed of 4.0 m/s, starts after A from the same place exactly 5 min later.
a.) At what time will runner B catch up with runner A?
b.) If the runners stop when B catches A, how far do they run?
So far I have 4.0 m/s*300 s = 1.2 Km and 3.0 m/s x 300s= 0.9 km, but I don't even know if this is the right aproach, can anyone help me from here?
They are two linear equations(with one solution I believe), find the point of intersection.
I will not tell you the answer, but merely try to open your eyes.
You know the velocities of A and B.
What formula do you use to find the velocity?
Try to combine the formulas to come up with an answer.
Hint: You need to use algebra. The distance traveled must be equal for both because that is when B catches up to A.
Show me some more work, and I'll be back to give more advice.
Note: I can tell you more right now, like most people, but doing it on your feels so much better.
Trying
so...
If I let the time A runs be "t", then the time B runs is "t- 5".
...4.0 m/s= t-5
and 3.0= t
So... 4.0 m/s= 3.0-5
I'm I on the right track?
Huh?
To take that route I believe you will need to convert the minutes into seconds since your velocity is 4.0m/s.
Look at what you wrote. You said 4=3-5. We know that's incorrect already.
The formula for velocity is [tex]v=d/t[/tex].
Because there is two different velocities, there is two different equations to work with.
With the two equations that you get, combine them.
Note: Remember, d will be the same for both.
Still trying
so...for B v=1.2 km/ 3.0
and for A v= .9 km/3.0, IF RIGHT, WHAT UNITS IS 3.0 IN, HR?
Wrong. I'm having a hard time trying to understand where you got this.
I'll give you the equation for B, since you kind of got it in your second post. A is very similar.
[tex]4.0m/s = \frac{d}{t_1-300s}[/tex] , 300s = 5min (converted into seconds).
You had t-5, but that was incorrect. Find equation A. Remember d is the same for both.
Combine both equations by isolating a term(d or t_1).
Note: I must go bang my head trying to fully comprehend SR.
Hopefully someone takes over if you are still stuck.
Also, read the first 2 chapters of your textbook. It will talk about dimensionalities(metres, seconds) and most likely average velocities.
That would help a lot.
There is also a forum for homework help, and they have helpful people there. Believe it or not, they have regulars for helping out.
Please avoid homework related problems in this forum. I made the mistake myself, so it's not big deal, so I'm letting you know.
so distance equal to 2.1?
Let's start with runner a.
If runner a moves at a velocity of 3 m/s, and he runs for 1 second, how many meters does he move?
If he runs for 2 seconds, how many meters does he move?
More advanced:
Can you write an equation for the position of runner a as a function of time?
That's what I was saying. I even gave the equation itself.
I would love to show you how it's done, but it is better to work it out yourself. Once you get that breakthrough, everything else becomes a little easier.
Note: The answer might be 2.1m because I never checked.
  • · Replies 17 ·
19K
