Rate of change of pressure with volume, adiabatic vs isothermal conditions
The discussion revolves around the rate of change of pressure with volume for a monatomic gas under isothermal and adiabatic conditions. The original poster presents a specific value for the isothermal condition and seeks to determine the corresponding rate for the adiabatic case.
  • Exploratory, Assumption checking
  • Participants explore the relationship between pressure and volume for both isothermal and adiabatic processes. They raise questions about deriving expressions for dP/dV in each case and discuss the implications of the given isothermal rate.
Some participants have provided hints and guidance on how to relate the isothermal and adiabatic conditions, while others express uncertainty about the necessary values to proceed with calculations. The conversation reflects an ongoing exploration of the problem without reaching a definitive conclusion.
Participants note the lack of specific values for n, T, and k, which are necessary for further calculations in the adiabatic case. The original poster acknowledges feeling stuck due to this missing information.
encasements
For a particular sample of monatomic gas, the rate of change of pressure with volume under isothermal conditions is -2 x 10^7 Pa m^-3. Calculate the rate of change under adiabatic conditions.
isothermal:
dP/dV = -2 x 10^7
Q = nRTln(Vf/Vi)
monatomic:
PV^(5/3) = constant
adiabatic:
dU = dW
I feel like this question should be easy but I just don't even know how to approach it. I'd be extreme grateful if anybody could point me in the right direction. Thanks.
isothermal:
dP/dV = -2 x 10^7
Q = nRTln(Vf/Vi)
monatomic:
PV^(5/3) = constant
adiabatic:
dU = dW
1. What is dP/dV in terms of nRT and V for the isothermal process?
2. What is the relationship between P and V in an adiabatic (reversible) process? (hints: it does not involve T and you need to know that it is a monatomic gas).
3. Find dP/dV for the adiabatic process by differentiating the equation in 2.
4. Compare the answers in 1. and 3. using the value for dP/dV that is given for the isothermal process.
AM
AM
Thanks for your help. This is what I have so far:
isothermal:
PV = nRT
=> P = (nRT)/V
=> dP/dV = -(nRT)/(V^2)
dP/dV = -2 x 10^7
=> -(nRT)/(V^2) = -2 x 10^7
adiabatic:
PV^(5/3) = k
where k is some constant
P = k/(V^(5/3))
=> dP/dV = -(5/3)k/(V^(8/3))
I see that if I had values for n, T, and k I could work out the volume and use that to calculate a value for dP/dV in the adiabatic case -- but since I don't have those values and I'm not sure how to find them I'm afraid I'm still a little stuck.
Well, you know that:
[tex]k = PV^\gamma[/tex]
and PV = nRT
and
[tex]nRT/V^2 = 2 \times 10^7[/tex]
AM
Thanks for all your help. I've got it now.
  • · Replies 16 ·
