| Thread Closed |
Spatial Light Modulator to remove high intensity light |
Share Thread | Thread Tools |
| Aug14-10, 11:06 AM | #1 |
Is there a way to use a Spatial Light Modulator or other device to remove high intensity light without removing low intensity (low amplitude) light from a physical object you are observing?
High intensity light would be completely filtered (removed) but low amplitude waves would not be removed. I considered using a half-silvered mirror to reflect part of waves and use destructive interference but I could not come up with a way to destructively interfere with only the high-amplitude waves. Note, dark "sunglasses" would not work because they attenuate both high intensity and low intensity light waves. |
| Aug14-10, 11:53 AM | #2 |
Recognitions:
Do you mean something like a DC stop?
These guys use something fancy: http://www.informaworld.com/smpp/con...ent=a789582077 but a small dot of white-out is sufficient to block the central peak. |
| Thread Closed |
| Tags |
| light filter, light modulator |
| Thread Tools | |
Similar Threads for: Spatial Light Modulator to remove high intensity light
| Faster than light time travel through controlled, spatial distortion... | Beyond the Standard Model | 11 | ||
| Small electro-optic modulator and phase-shifting light | Classical Physics | 1 | ||
| Why does light intensity decrease when light passes through a glass block? | General Physics | 7 | ||
| Intensity of light / measuring wavelength of light | Introductory Physics Homework | 2 | ||
| timeflow, light, spatial speed, quarks & anti-matter questions... | Quantum Physics | 4 | ||
