Solving Spherical Rolling Problem - Hossein
  • Context: Graduate
  • Thread starter Thread starter hmoein
    Rolling Spherical
The discussion centers on the mathematical relationship between the coordinates (X, Y, Z) of a sphere rolling on a fixed surface and its orientations defined by Euler angles (alpha, beta, gamma). It is established that a sphere has six degrees of freedom (DOF) in space, but when rolling, it effectively exhibits only three DOF due to the constraints of motion. The conversation highlights that the rolling sphere's orientation does not correspond directly to its position on the surface, particularly when considering non-holonomic constraints, as demonstrated by the example of a sphere rolling on a flat plane.
  • Understanding of spherical geometry and kinematics
  • Familiarity with Euler angles and their applications
  • Knowledge of degrees of freedom in mechanical systems
  • Basic concepts of non-holonomic constraints in physics
  • Research the mathematical formulation of non-holonomic systems
  • Explore differential geometry and its application to rolling motion
  • Study the relationship between rotation matrices and Euler angles
  • Investigate practical applications of rolling spheres in robotics and simulations
This discussion is beneficial for physicists, mechanical engineers, and robotics researchers who are exploring the dynamics of rolling objects and their mathematical modeling.
hmoein
hi , every one!
I have a problem with a sphere rolling on a fixed sphere. My problem is to find relationship between coordinate of center of sphere (X,Y,Z) and orientations (alpha, beta, gamma) or Euler angles of sphere. as we know a sphere has 6 DOF in space (3 coordiantes and 3 rotation) when a sphere rolling on surface we expect that it have 3 dof beacuse of relation beween coordinate and rotation.
for example when a circle roll on a surface the x coordinate of its center is:
X=R*teta (R = radius of circle) and it has one DOF.
Like the circle rolling i want to find the relations for sphere.
thanks
hossein
Unfortunately, the constraint for a sphere rolling on a 2-dimensional surface cannot be integrated; it is "non-holonomic". Consider, as a simple case, a sphere rolling on a flat plane without slipping.
By rolling the sphere around a closed path, back to its starting point, you can imagine that in general the sphere will not end up in exactly the same orientation as it started; it will be rotated about the normal axis. Therefore, there is not a 1-to-1 correspondence between locations on the plane and orientations of the sphere.
You can construct differential relations, though; however, they will be more difficult to use.
thanks
  • · Replies 97 ·
