| Thread Closed |
Antenna, transmission line |
Share Thread | Thread Tools |
| Sep8-04, 10:46 AM | #1 |
Hi,
I want to clarify some notiona in an antenna. The major components of an antenna are a generator, transmission line and an antenna (dipole). Let's say the whole system has a perfect matche, i.e. the dipole is about 70 ohms as the transmission line. If my generator ,the output voltage, is an impulse which has a duration in a micro second ( let's say 1 micro sec). So, the frequency of this generator is 1 Mhz? If the impluse is a square, the main fundamental frequency is 1 MHz and also , with others harmonics, I means if I do the Fourier Transformation am I right? Thanks, Mica |
| Sep8-04, 01:06 PM | #2 |
A square wave is composed of odd integer harmonics. The third, fifth, seventh, and higher order odd harmonics all have power in them.
- Warren |
| Sep8-04, 03:10 PM | #3 |
Thanks, Mica |
| Sep8-04, 03:54 PM | #4 |
http://mathworld.wolfram.com/Fourier...quareWave.html
Look at equation 6. The third harmonic has a frequency three times that of fundamental, and has an amplitude one-third that of the fundamental. The fifth harmonic has a frequency five times that of the fundamental and an amplitude one-fifth that of the fundamental. - Warren |
| Sep9-04, 03:13 PM | #5 |
Thanks for the information. So, for my dipole radited efficiently, I just match the right frequency output of the generator ? I mean like if my dipole resonances at 1 GHz so, my impluse (voltage source) duration will be 1/1 GHz ( 1 nano second) independent of the wave form?
Mica |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Antenna, transmission line
| transmission line question | Electrical Engineering | 7 | ||
| Transmission line termination? | Electrical Engineering | 11 | ||
| Transmission antenna | General Engineering | 8 | ||
| Need Help on a transmission line problem 1! | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Transmission line question. | Electrical Engineering | 3 | ||
