Time Uncertainty: Pulsar Rotation & Atomic Clocks
  • Thread starter Thread starter GingerBread27
    Time Uncertainty
The discussion centers on the use of pulsars as a potential standard for measuring time, alongside atomic clocks. Specifically, a pulsar with a rotation period of 1.424 806 448 872 75 2 ms is analyzed for its rotation frequency and associated uncertainties. Calculations reveal that this pulsar rotates approximately 1.27 billion times in 21 days and takes 1424.8064 seconds to complete 1 million rotations. The uncertainty in this time measurement is determined to be 0.02 ms, indicating a range of 1424.8062 to 1424.8066 seconds for the total time of 1 million rotations.
  • Understanding of pulsar mechanics and properties
  • Familiarity with atomic clock technology
  • Basic knowledge of uncertainty calculations in measurements
  • Proficiency in scientific notation and unit conversions
  • Research the principles of pulsar timing and its applications in astrophysics
  • Study the methods of calculating uncertainty in scientific measurements
  • Explore the differences between atomic clocks and pulsar-based timekeeping
  • Investigate the stability and reliability of various pulsars for time standards
Astronomers, physicists, and anyone interested in advanced timekeeping methods and the precision of astronomical measurements will benefit from this discussion.
GingerBread27
Time standards are now based on atomic clocks. A promising second standard is based on pulsars, which are rotating neutron stars (highly compact stars consisting only of neutrons). Some rotate at a rate that is highly stable, sending out a radio beacon that sweeps briefly across Earth once with each rotation, like a lighthouse beacon. Suppose a pulsar rotates once every 1.424 806 448 872 75 2 ms, where the trailing 2 indicates the uncertainty in the last decimal place (it does not mean 2 ms).
(a) How many times does the pulsar rotate in 21.0 days?
The answer is 1.27e9
(b) How much time does the pulsar take to rotate 1.0 x 10^6 times? (Give your answer to at least 4 decimal places.)
The answer is 1424.8064 seconds
(c) What is the associated uncertainty of this time?
For this problem I am unsure of how the uncertainty is calculated. I understand parts a and b but not C. Please help.
Why don't you use upper and lower possible values for the period, calculate the two corresponding answers and make the difference between them ?
The uncertainty in time for a pulsar rotation is typically calculated by considering the uncertainty in the measured rotation period. In this case, the uncertainty is represented by the trailing 2 in the given rotation period of 1.424 806 448 872 75 2 ms. This means that the actual rotation period could be anywhere between 1.424 806 448 872 75 0 ms and 1.424 806 448 872 75 4 ms.
To calculate the associated uncertainty in time, we can use the formula:
uncertainty in time = uncertainty in rotation period * number of rotations
For part (c), the uncertainty in time would be:
uncertainty in time = (0.00000000000000002 ms) * (1.0 x 10^6 rotations)
Thus, the associated uncertainty in time would be 0.02 ms. This means that the actual time for 1.0 x 10^6 rotations could be anywhere between 1424.8062 seconds and 1424.8066 seconds.
It is worth noting that this uncertainty may be smaller or larger depending on the precision of the measurements and the stability of the pulsar rotation.
14K
  • · Replies 34 ·
