Calculating the highest point of a trajectory
  • Thread starter Thread starter sjduhig
    Point Trajectory
The discussion focuses on calculating the highest point of a soccer ball's trajectory when kicked with an initial velocity of 20 m/s at an angle of 20 degrees. The vertical distance to the highest point is determined using basic equations of motion under uniform acceleration, specifically considering the gravitational acceleration acting in the vertical direction. The horizontal motion is not factored into the height calculation, as there is no acceleration in the x-direction.
  • Understanding of basic physics concepts, particularly projectile motion.
  • Familiarity with equations of motion under uniform acceleration.
  • Knowledge of trigonometric functions to resolve velocity components.
  • Grasp of gravitational acceleration, typically approximated as 9.81 m/s².
  • Study the equations of motion for projectile motion in detail.
  • Learn how to resolve vectors into their components using trigonometry.
  • Explore the effects of different launch angles on projectile height and range.
  • Investigate the impact of air resistance on projectile trajectories.
Students and educators in physics, sports scientists, and anyone interested in understanding the mechanics of projectile motion and its applications in real-world scenarios.
sjduhig
1. A soccer ball is kicked with an initial actual velocity of 20 ms at an angle of 20 degrees with the horizontal. Find the vertical distance from ground to highest point.
Take ground as x-axis and perpendicular as y axis. There is no acceleration in x direction.As acceleration in y-axis is gravity, and only y component of velocity is responsible for max height just use basic equations of motion under uniform acceleration and find out the answer.
  • · Replies 38 ·
9K
  • · Replies 21 ·
