Can a Spaceship Always Spot the Lone Inhabitant on a Spherical Planet?
  • Thread starter Thread starter Heirot
    Planet
The problem involves a spherical planet with a single inhabitant who can move freely on its surface, while a spaceship approaches the planet at a certain velocity. The task is to determine conditions under which the spaceship can always see the inhabitant, particularly when the ratio of the spaceship's speed to the inhabitant's speed exceeds 10.
  • Participants express uncertainty about the nature of the problem, questioning whether it is relativistic or classical. Some suggest that assumptions may need to be made due to perceived incompleteness in the problem statement. Others discuss the implications of initial conditions and the visibility of the inhabitant based on the spaceship's position and speed.
The discussion is ongoing, with various interpretations being explored. Some participants suggest that the problem may involve game theory to analyze optimal strategies for both the inhabitant and the spaceship. There is a recognition that the ratio of speeds may not be the only factor influencing visibility, and multiple viewpoints are being shared without a clear consensus.
Participants note that the problem may require additional assumptions and that the initial conditions could significantly affect the outcome. There is also a mention of the potential for confusion regarding the specific numerical value of 10 in the problem statement.
Heirot
Spherical planet has only one inhabitant that can move freely on the surface of the planet with speed u. A spaceship approaches the planet with velocity v. Show that if v/u > 10, the spaceship can always see the inhabitant regardless of his movement.
No idea.
I have no idea where to start. Is this supposed to be a relativistic problem or a classical mechanical one? Any hints are more than welcome!
What class/chapter is this for? Has me stumped atm unless the problem statement is incomplete.
Our professor gives us all kinds of problems so that we become versatile physicists like Landau. This one came under mathematical physics.
Problem is incomplete. That suggests you should make some assumptions on your own. However, it is pretty easy to construct initial conditions such that the ship doesn't see the inhabitant the moment it starts, so obviously you can't prove the statement. OTOH, if ship is close enough (it hovers just above the inhabitant head) it is enough that v/u > 1.
Sorry, I wasn't clear enough - the ship should see inhabinant eventualy, not neccessarily at the initial moment. If he's on a planet, he can't hide forever. With that said, I presume the worst initial conditions result in a factor 10.
Ah, well that's not what the problem said originally (it said "always see the inhabitant").
Anyway, to provide a really solid solution, I think you'd have to start with a little game theory, to figure out the optimal escape strategy for the planet's inhabitant and the optimal search strategy for the ship to counter it. Already that seems way outside the scope of a physics class. (Interesting problem, though)
I suppose you could think about how much of the planet can be seen at a time from the ship, and see if that leads to anything... although I thought about it a bit and I still don't see where the 10 comes from.
I think that 10 is an approximation of pi^2.
One of my guesses would be that if the planet has a radius R and the ship is displaced by d from the center of the planet, then, one can calculate the amount of the planet surface seen from the ship (let's call it ship's area). It decreases with d. The worst case scenario is that the inhabitant is initially on the other side of the planet. If the ship can get to the other side faster then the inhabitant can escape the ship's area located in the point where the inhabitant was at the beginning then the ship can locate the inhabitant. Unfortunately, this doesn't give pi^2 nor 10.
Hm, π² at least seems less random...
Actually it increases with d, doesn't it? Take Earth as an example: if you're just above the surface, you can only see a few miles in any direction at best, but from the ISS in low orbit, you can see entire continents. And looking from the moon, you see nearly half the Earth's surface. So the further away you are, the more you see.
Of course, I still can't think of anything that would really clarify this problem either...
Yes, you're right - I mistyped.
Hm, so I was not the only person to think that 10 looks ridiculously round for an answer :biggrin:
Yeah, it's awfully suspicious-looking, sitting there nonchalantly without a decimal point :wink:
19K
  • · Replies 75 ·
  • · Replies 42 ·
