Electric potential of a conductor.
The discussion revolves around the concept of electric potential in relation to charged conductors and the effects of bringing an earthed object close to them. Participants explore the implications of electric potential on the surface of conductors and the behavior of charges within conductive materials.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants question the definition of electric potential in the context of charged conductors, specifically whether it refers to the surface potential or otherwise. There is also exploration of how an earthed object influences the potential of a nearby charged conductor and the implications of induced charges.
Some participants have clarified misconceptions regarding the relationship between earthed objects and charged conductors, noting that the potential of the earthed object is zero. Others are still grappling with the concept of how the potential of a charged conductor is affected by the presence of an earthed object, indicating ongoing exploration of the topic.
Participants express confusion regarding the uniform distribution of charge on the surfaces of a spherical metallic shell when a positive charge is placed inside it, particularly in relation to the distance from the center of the shell.
Terocamo
I know the definition of electric potential is the work done to bring a test charge from infinity to a particular point.
But I read about some question asking the electric potential of a charged conductor,
I wonder what that means, whether it is the potential of the surface of the conductor or otherwise.
Also, I don't understand the concept of bringing a earthed object close to a charged conductor will
decrease the magnitude of potential of that charged object.
eg. my notes mention the induced charge inside the eathed object contrubutes a positive potential
to make the potential of the negative charged conductor LESS negative. Itsn't an earthed object
have zero potential? So how can it contrubute any potential.
Thz :blushing:
What do you mean by "otherwise"? A conductor is an equipotential which means that all points that make up this conductor whether on the surface or underneath the surface are at the same potential.
Thz :blushing:
The earthed conductor is always at zero potential. If you bring it close to a negatively charged conductor, free electrons inside the earthed conductor will be pushed into the Earth as they are repelled by the negative charges on the other conductor. The loss of negative charges in the earthed conductor raises the potential of the negatively charged conductor because it is essentially a gain of positive charge in that region of space.
Thz first, you clear some of my wrong concepts, but i am still puzzled by how the potential is raised.
I now understand the earthed object gains positive charge and produce a field to compensate
the potential due to the negative charge conductor in order to maintain zero potential. (I hope
thats a right concept :bugeye:)
Is it that potential due to the earthed object raised the potential of the charged object? :confused:
Ive got another question about electric field.
There is a spherical metallic shell of uniform thickness which is neutral. A positive charge is put inside it
but not anywhere close to the centre of the spherical shell. Why is it the charge deposit on the outer and inner surface of the
shell distrubute unitformly?
Itsnt the electrostatic force stronger if closer? I thought the negative charge will gathered
at a pt close the the positive charge and it will disturb the distrubution of charge.
Yes. The potential of the earthed object is always zero.
The charge on the outer surface only is distributed uniformly if the charge inside the cavity is off center. To get uniform distribution on the inner surface, you need to have the charge in the center. You can change the charge distribution on the inner surface by moving the charge in the cavity around, but that does not affect the charge distribution on the outer surface because the electric field inside the conductor is always zero so the inside distribution cannot communicate to the outside distribution what is happening to it.
Thz again, it is very helpful.
  • · Replies 22 ·
  • · Replies 17 ·
