Min and Max of Parallel Resistors
The discussion focuses on the behavior of resistors in parallel circuits, specifically analyzing the minimum and maximum resistance values when R1 is less than R2. The minimum resistance is established as (R1)/2, while the maximum approaches R1. The formula for two resistors in parallel is given as R1.R2/(R1 + R2). Empirical observations suggest that for n resistors, the minimum resistance is (R1)/n and the maximum is R1, with further exploration needed to prove these mathematically.
  • Understanding of parallel resistor circuits
  • Familiarity with resistance calculations and formulas
  • Basic knowledge of calculus, particularly partial derivatives
  • Experience using WolframAlpha for mathematical plotting
  • Research the mathematical proof for resistance in parallel circuits
  • Explore the implications of varying resistor values in parallel configurations
  • Learn about the behavior of resistors in series versus parallel
  • Investigate advanced circuit analysis techniques using software tools
Electronics enthusiasts, electrical engineering students, and anyone interested in circuit design and analysis.
meeep
I noticed that, for resistors in a parallel circuit, where R1 is < R2, the minimum value is (R1)/2, and the maximum approaches R1.
I was trying to work out why, so for two resistors, the calculation is:
R1.R2/(R1 + R2).
I thought of partial derivatives but not sure where to go after that, and after getting the curve in WolframAlpha, not sure what to do with that either.
http://www.wolframalpha.com/input/?i=plot+xy/(x+y)
Empirically, the nth case appears to be: min = (R1)/n and max = R1, but not sure how to prove it mathematically.
Any advice on what I could try next? This isn't homework, just noticed it and got curious.
Mathematics news on Phys.org
Assume that R1 is some fixed number. All that we know is that R2 must be bigger than R1. So to find the minimum resistance, R2 should be as small as possible, and to find the maximum resistance, R2 should be infinitely large.
Try seeing what happens to the resistance when you make R2 as small as possible (keeping in mind it must be bigger than R1) and what happens when R2 is arbitrarily large
  • · Replies 24 ·
