Understanding the Hyperbolic Distance Formula: Deriving Log QA.PB/QB.PA
  • Context: Graduate
  • Thread starter Thread starter Kevin_Axion
    Formula Hyperbolic
The discussion focuses on the Hyperbolic Distance Formula as introduced in Roger Penrose's book, The Road to Reality. The formula for the distance between two points A and B in hyperbolic space is defined as log(QA.PB/QB.PA), where log represents the natural logarithm and '.' denotes multiplication. Euclidean distance is defined using the formula √((x-x')² + (y-y')²) or |z-z'| in complex notation. To derive the hyperbolic distance formula, one must understand fractional linear transformations, specifically those of the form z → (az+b)/(cz+d), which are invariant under conformal transformations.
  • Understanding of Euclidean distance in two-dimensional space
  • Familiarity with complex numbers and their representation
  • Knowledge of fractional linear transformations
  • Basic concepts of hyperbolic geometry and conformal mappings
  • Study the properties of fractional linear transformations in detail
  • Explore the concept of conformal mappings in hyperbolic geometry
  • Learn about the mathematical foundations of hyperbolic space
  • Investigate the applications of hyperbolic distance in various fields
Mathematicians, physicists, and students studying geometry, particularly those interested in hyperbolic geometry and its applications in theoretical physics.
Kevin_Axion
I'm currently reading through Roger Penrose's book The Road to Reality and in his Hyperbolic Geometry discussion he introduces the concept of how to define the distance between two points. He defines a Conformal Representation of a Hyperbolic Space bounded by a circle and then he states there are two points A and B (within the hyperbolic space) and there is a hyperbolic line (an arc/Euclidean Circle) That intersects A and B and meets orthogonally to the bounding circle at points P and Q. Where QA etc are the Euclidean distances. The distance between A and B is thus defined by the formula,
log QA.PB/QB.PAWhere log is the natural logarithm and '.' is multiplication, assumingly.Firstly, can you please define a Euclidean distance and secondly can you help me understand how to derive this formula?
Thanks
Thanks
On the plane Euclidean distance between points [tex](x,y)[/tex] and [tex](x',y')[/tex] is
[tex]\sqrt{(x-x')^2+(y-y')^2}[/tex]
Or, if you set [tex]z=x+iy[/tex] it is [tex]|z-z'|[/tex]
To derive this formula one has to know the assumptions. One possibility is to consder the group of fractional linear transformations of the form
[tex]z\mapsto\frac{az+b}{cz+d}[/tex]
with real a,b,c,d and [tex]\det (\{a,b;c,d\})\neq 0[/tex]. (search the net for [tex]PSL(2,R)[/tex]) These 'conformal' transformations map the (closed) unit disk into itself. Then seek a distance formula that is invariant under these transformations.
Thanks.
  • · Replies 29 ·
