PCB Fabrication at Home: Basics & Acids Needed
This discussion focuses on the home fabrication of printed circuit boards (PCBs) using UV light exposure and chemical etching. The user mentions using a kit from Elexp, which includes a developer and ferric nitrate as the etchant. Key issues highlighted include the importance of proper exposure time and developer dilution to achieve successful PCB etching. Over-exposure or under-exposure of the board can lead to inadequate results, emphasizing the need for precise control in the fabrication process.
  • Understanding of PCB fabrication processes
  • Knowledge of UV light exposure techniques
  • Familiarity with chemical etchants like ferric nitrate
  • Experience with developer solutions for PCB processing
  • Research proper dilution ratios for PCB developer solutions
  • Learn about UV exposure times for different PCB materials
  • Investigate alternative etchants for PCB fabrication
  • Explore troubleshooting techniques for common PCB fabrication issues
This discussion is beneficial for hobbyists, electronics enthusiasts, and anyone interested in DIY PCB fabrication techniques at home.
hisham.i
Hello, am trying to make pcb at my home, but am not sure about the sequence of fabrication steps.
i put the board in UV light for several minutes, then i put it in a basic solution and finally in ana acidic one, but nothing happened to my board...
What are the names of bases and acids used for this purpose?
I got a kit from here:
http://www.elexp.com/pro-pcb.htm
If I remember correctly there is a developer for the exposed board and then a ferric-nitrate or some such etchant. If you get no image on the board after the exposure and development, and nothing etches, then I suspect you are way over-exposing -- possibly your transparency is not dense enough in the dark areas. If everything etches away then it's way under-exposed. I remember that I had a little brain-fade when I first tried the kit and didn't dilute the developer correctly, which lead to a seeming under-exposure condition too.
  • · Replies 19 ·
11K
10K
