Thread Closed
Reactor Design
Share Thread
Aug27-10, 12:50 PM   #1
Reactor Design
When designing a core lattice, which one of the thermal-hydraulics and neutronics consideration are important?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Aug27-10, 02:02 PM   #2
Admin
Neutronics, or rather, power distribution goes hand in hand with thermal hydraulics.
Basically one has to do the nuclear design subject to the constraint imposed by the thermal hydraulics (thermal boundary conditions).
There's an interplay also with the moderation, moderator temperature coefficient, in addition to the critical heat flux (CHF) and the margin to CHF.
One also has to be mindful of 10 CFR 50, App. A and the General Design Criteria, particularly GDC 10, 27 and 35, which are frequently cited in NUREG-0800, Standard Review Plan, particularly Section 4.2, Fuel System Design.
http://www.nrc.gov/reading-rm/doc-co...t050-appa.html
Reactor
http://www.nrc.gov/reading-rm/doc-co...ff/sr0800/ch4/
4.2 Fuel System Design
4.3 Nuclear Design
4.4 Thermal and Hydraulic Design
Aug27-10, 07:46 PM   #3
How about moderation-to-fuel ratio?
Aug27-10, 07:56 PM   #4
Admin
Reactor Design
Quote by candice_84 View Post
That's one parameter.
One has to do a balance between fuel pellet diameter/cladding diameter/ and rod pitch. One can open up the lattice which is cooler, but there is more leakage of neutrons.
Or for a given pitch, one can make a smaller fuel rod diameter, but that drives of the heat flux for a given linear power.
Of course, my example applies to a tubular design.
One can make a core a bit more homegeous with spherical fuel particles which pretty much necessitates a gas like He, Ne, CO2 for heat transfer. Reactivity management can be more of challenge though.
Then again, one could used a liquid fuel, e.g., molten salt, but that requires special considerations of the primary circuit and heat exchangers.
Aug27-10, 08:24 PM   #5
Is it true,If we increase the fuel, the fuel utilization increases? therefore moderation-to-fuel ratio decreases and the reactor becomes under moderated?
Aug27-10, 08:40 PM   #6
Admin
Yes, and that would harden the spectrum. In BWRs, one can reduce flow and increase voiding in an assembly and harden the spectrum. The harder spectrum produces more Pu-239 from conversion of U-238, which can increase fuel utilization. That operation is called spectral shift.
So-called standard 17x17 PWR fuel has a UO2 pellet diameter of 0.3225 inch (8.19 mm), and cladding OD of 0.374 inch (9.5 mm). The lattice pitch is 0.496 inch (12.6 mm).
In the 1980s, Westinghouse introduced an optimized 17x17 which used a slightly thinner fuel rod which used a pellet with an OD of 0.3088 inch (7.84 mm) and cladding OD of 0.360 inch (9.14 mm) in the same lattice. The same fuel rod dimension is used VVER-1000 fuel assembly, but the lattice is triangular/hexagonal.
With the fatter fuel rod, one can load more fuel into the core, which can be used to reduce enrichment (and SWU costs), or go for slightly longer cycle length/exposure.
Aug28-10, 04:45 AM   #7
Is there any advantage for the Russian design to be hexagonal over PWR lattice, or they just wanted to make it look different?
Aug28-10, 06:16 AM   #8
Admin
With respect to advantage, one has to look at the fuel moderator ratio, and critical heat flux.
The pitch of the VVER-1000 fuel rod is 0.5 inch (12.7 mm), but that is on a triangular geometry rather than a square lattice geometry. One should also look at the hydraulic diameter, as well as the fast to thermal flux ratio, or relative proportions in different neutron energy groups.
I understand that the VVER lattice is well suited for thorium based plants.
Aug28-10, 09:31 AM   #9
Where do they fit a flux detector in either pwr or vver? Is it inside the fuel rod? also does it conflict with absorber rods? Also when you mentioned about spectrum what spectrum exactly you are pointing on?
Aug28-10, 10:22 AM   #10
Admin
One can do both in-core and ex-core detectors. The problem with ex-core detectors is that the neutron flux is very low at the core periphery.
In-core detectors are usually placed in an instrument tube, and the incore instrumentation includes thermocouples for core inlet or core outlet. The instrument tube is like a guide tube, but it is usually centrally located in an assembly of odd-numbered rows (15 x15 or 17x17) or slightly off-set from center in 14x14 or 16x16 assemblies, except for CE plants which have 4/5 guide tubes displacing 4 fuel rods.
AREVA's EPR is designed to use a guide tube instead of an instrument tube, and the EPR fuel assembly has 265 fuel rods instead of the traditional 264 fuel rods of a 17x17 lattice. W's AP-1000 and Mitsubishi's US-APWR use the traditional centrally located instrument tube. The instrumentation is placed in an unrodded location, i.e., no control rods in the assembly. AREVA also uses a pneumatic activation analysis system, which is based on Siemens technolgoy, in addition to typical SPN detector strings.
Some plant designs had incore probes inserted from below the core, but the modern plants favor insertion from the top.
Aug28-10, 10:23 AM   #11
Admin
Neutron energy spectrum.
Aug28-10, 01:01 PM   #12
Can we use the same 17x17 fuel assembly in fast reactors? also what materials are suited as an absorber for fast reactor, because I was checking the cadmium's cross section and noticed it doesn't absorb at high energy level.
Aug28-10, 01:25 PM   #13
Admin
Fast reactors generally use hexagonal lattices.
The reference structural material for fast reactors is SS316 - both core and fuel structures. Other steels have been developed for improved creep resistance and reduced swelling.
One can find information here on the Clinch River Breeder Reactor
http://www.osti.gov/bridge/servlets/...UJ/4281663.pdf
Otherwise there is EBR-I, II at INL (INEL).
One can search on EBR-II and FFTF driver fuel.
Unfortunately, when FFTF was mothballed and trashed, a lot of fuel material was dumped and a lot of information was tossed. :(
A good reference is the Proceedings from an ASTM conference: Effects of radiation on materials / Radiation-induced changes in microstructure.
Example: http://books.google.com/books?id=k5j...A146&lpg=PA146
Aug28-10, 02:11 PM   #14
Quote by Astronuc View Post
Fast reactors generally use hexagonal lattices.[/url]
Since there is no moderator involved in fast reactors, I assume hexagonal lattices perform better thermal-hydraulics than rectangular 17x17 in general. Is this a right assumption? Can you provide me a reference that shows how to mathematically do thermal-hydraulics analysis?
Aug28-10, 02:23 PM   #15
Admin
I believe that the tringular/hexagonal lattice is better from a neutronic standpoint. The neutron leakage is more before the mean free path of a fast neutron is much greater in a fast reactor than in a thermal reactor. In the latter, fast neutrons slow down relatively quickly.
The thermalhydraulics in a fast reactor is a bit different since it is liquid metal, Na or NaK, or if one wants to get really exotic, Li. One has to be concerned with the positive void coefficient.
I believe that the control elements were B4C based. It's been a while since if reviewed the technology.
I'll see if I can find a good reference on fast reactor T/H. Probably Waltar and Reynolds is the best text on fast reactors.
Aug28-10, 02:33 PM   #16
In the pdf file for LMFR it says that LMFR don't need emergency cooling systems but I don't understand it.
Aug28-10, 03:21 PM   #17
Admin
Probaby there is a decay heat removal system, but not an ECCS like that of an LWR. The liquid metal coolant has excellent thermal conductivity, and I suspect that in shutdown, there is an effective heat removal system and one does not have to be concerned of the core overheating or the coolant boiling as the case with an LWR. The problem for LWRs is that they have to operate under high pressure to maintain a liquid phase. Na systems operate at a few atmospheres. IIRC, a Na loop at 0.20 or 0.5 MPa (about 2 to 5 atm) provides much the same heat transfer coefficient as pressurized water at 2250 psia (15.5 MPa), 290 C (563 K).
Thread Closed
Similar discussions for: Reactor Design
Thread Forum Replies
Nuclear Reactor Design Nuclear Engineering 3
DOE judges IFR best reactor design Nuclear Engineering 5
How is high temperature reactor design different? Nuclear Engineering 3
reactor design/systems design Nuclear Engineering 24
Design of a chemical reactor Chemistry 13
