It seems easy, but I don't get it
  • Context: Undergrad
  • Thread starter Thread starter Karlx
The discussion revolves around a probability problem involving urns containing balls of different colors. Participants are analyzing the conditions under which a specific configuration of balls remains after drawing two black balls, and they are trying to determine the value of n based on the given probabilities.
  • Homework-related
  • One participant proposes that n=6 based on their reasoning about the probabilities of drawing from urns with different initial configurations.
  • Another participant argues that the probability of having five white and three black balls remaining is zero for the urns with only four white balls, suggesting that n must be equal to 6.
  • A third participant introduces the events E and B, indicating that P(E | B=2) = 1/7 and suggests using the definition of conditional probability to analyze the problem further.
  • A later reply discusses the application of the multiplication rule in probability and concludes that applying it correctly leads to the result n=4, which matches the book's solution.
Participants express differing views on the correct value of n, with some supporting n=6 and others concluding n=4. The discussion remains unresolved as participants present competing interpretations of the problem.
There are unresolved aspects regarding the application of probability rules and the assumptions made about the urns' configurations. The discussion highlights the complexity of conditional probabilities in this context.
Karlx
Hi everybody.
Once more, I need your help.
The following is a problem that appears in Rohatgi's "An introduction to Probability and Statistics":
"Each of n urns contains four white and six black balls, while another urn contains five white and five black balls. An urn is chosen at random from the (n+1) urns, and two balls are drawn from it, both being black. The probability that five white and three black balls remain in the chosen urn is 1/7. Find n."
My first guess would be that n=6, but the solution given in the book is n=4.
Someone can tell me if I am wrong or there is a mistake in the book ?
Thanks.
My guess is the following one:
The probability that five white and three black balls remain in the chosen urn is zero for the n urns that had initially only four white balls.
For the urn that had initially 5 white and 5 black balls, the probability of having 5 white and 3 black balls after having drawn 2 black balls is 1.
The probability that this former is the chosen urn is 1/(n+1).
So n must be equal to 6.
Am I wrong or there is a mistake in the book?
I would appreciate your hints.
Thanks
Let's say E is the event that the urn with 5 white and 5 balls is chosen, and B is the number of black balls drawn. You are told that
[tex]P(E \;|\; B=2) = 1/7[/tex].
By definition, [tex]P(E \;|\; B=2) = \frac{P(E \; \cap \; B=2)}{P(B=2)}[/tex].
Take it from there.
Thanks for your answer, awkward.
This was my first attempt to the problem, but I wrote it in the following terms:
Let's say A is the event that five white and three black balls remain in the chosen urn, B is the number of black balls drawn and Cm is the event that the urn m has been chosen.
Then we are told that
[tex] P(A \;|\; B=2) = \frac{P(A \; \cap \; B=2)}{P(B=2)}[/tex]
where
[tex] P(A \; \cap \; B=2) = \sum_{m=1}^{n+1}p(C_{m})p(A\; \cap \; B=2 \;|\; C_{m}) = \sum_{m=1}^{n+1} p(A\; \cap \; B=2 \cap \; C_{m})[/tex]
and my problem was that I did not apply correctly the multiplication rule, that is
[tex] p(A\; \cap \; B=2 \cap \; C_{m}) = p(C_{m}) p(B=2 \;|\; C_{m}) p(A \;|\; B=2 \cap \; C_{m})[/tex]
If I apply it correctly, then I obtain the result n=4, the same that appears in the book, and indeed the same if I apply your hint.
Thanks a lot.
