Free Body Diagrams on friction less surface
The problem involves a 270-g block on an inclined frictionless surface at an angle of 34.4° and a 75.0-g block connected via a pulley. Participants are tasked with drawing free-body diagrams and determining tension, acceleration, and motion direction of the blocks.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the components of forces acting on the blocks, particularly the parallel and perpendicular components of weight. There are attempts to set up equations based on free-body diagrams, and questions arise regarding the relationship between the accelerations of the two blocks.
Some participants have provided guidance on identifying forces and setting up equations. There is recognition that both blocks share the same acceleration due to their connection, although some confusion remains regarding the correct application of force components and solving the equations.
Participants express uncertainty about the correct equations and the implications of the blocks being connected by a rope and pulley. There is a mention of potential missing information or misunderstandings about the setup of the problem.
dch1runs
1. A frictionless surface is inclined at an angle of 34.4° to the horizontal. A 270-g block on the ramp is attached to a 75.0-g block using a pulley, as shown in the figure below.
(a) Draw two free-body diagrams, one for the 270-g block and the other for the 75.0-g block. (b) Find the tension in the string and the magnitude of the acceleration of the 270-g block. (c) The 270-g block is released from rest. How long does it take for it to slide a distance of 0.90 m along the surface? (d) Will it slide up the incline, or down the incline?
F=m/a
Ok, so I'm having a lot of problem finding part (a). I'm pretty sure once I do, that b-d won't be very difficult at all. I rewrote the F=ma equation for both objects based on my free body diagrams. For the 75g object I had: a=g-T/m or a=9.81 m/(s*s) - T/.075g. For the 270g object i found that a=T/m-g*cos34.4. However when I try to solve as a system of equations my answers continue to be incorrect. Maybe the accelerations for the two objects are different? If so, then I have no idea where to go from there.
What's the component of the 270-g block's weight parallel to the incline?
Its not given, but I think its 9.81cos34.4?
No. First off, the weight equals mg. mg*cosθ would be the component perpendicular to the incline.
Does that mean that it would be mg/cos34.4?
No. Learn how to find the parallel and perpendicular components here: http://www.physicsclassroom.com/Class/vectors/u3l3e.cfm"
Thank you for that. So now I can find the perpendicular and parallel components. The parallel component would be m*g*sin(theta). Which in this example is .27kg*9.81m/(s*s)*sin34.4 I think. But its still not the magnitude of the acceleration, right? I know the site said to divide by the mass again, leaving the equation as g*sin(theta). But when I solve it, the application still tells me that I have the wrong answer. What else am I missing? Again thanks for your help.
Good.
The acceleration would be g*sin(theta) if there were no other forces acting on the mass, but that's not the case here.
Identify the forces acting on each mass and set up your force equations:
ΣF = ma (for mass #1)
ΣF = ma (for mass #2)
Then combine the two equations to solve for the tension and the acceleration.
So for the 75g object the forces acting on it are gravity and the rope.
F=m*a=m*g-T
The 270g object also has gravity (though only the parallel component) and the rope.
f=m*a=T-g*sin(theta)
But I still can't find the answer when putting them together and solving for tension and acceleration, are the accelerations different? If so then I only have two equations with three variables. I feel like I'm making this a lot more difficult than it really is.
F=m*a=m*g-T
Good. To make sure you keep the masses separate, write it as:
m1*a = m1*g - T
You left out the mass when you found the parallel component of the weight. Write it as:
m2*a = T - m2*g*sin(theta)
Now try combining them. (Hint: Just add them.)
Alright, so I finally got it! Thank you, although I do have one general question with this type of problem. How is it that both objects have the same acceleration, is it because they are connected by the rope and pulley?
Exactly right. The connecting rope forces them to have the same acceleration. Cut the rope and they will move independently.
Note that in writing your equations you implicitly made use of that fact.
  • · Replies 25 ·
  • · Replies 33 ·
