How effective are materials for good wear in a dry-running air motor?
  • Thread starter Thread starter Mike_In_Plano
    Materials
The discussion revolves around the effectiveness of materials used in a dry-running air motor designed to operate for 25,000 hours at speeds between 5,000 and 20,000 RPM. Participants explore material combinations for gears and endplates, concerns about wear, and alternative bearing solutions.
  • One participant, Mike, questions the suitability of materials like steel, Delrin, and ceramic for the gears and endplates, suggesting that endplates may need to be under compression to minimize air leakage.
  • Another participant mentions that bearing material manufacturers provide wear rate data, which can vary based on speed, pressure, and the material of the countersurface, and points to Dupont's resources on Delrin's wear characteristics.
  • A different participant argues against the feasibility of using a dry plastic bearing at 25,000 RPM, suggesting that it would melt, and proposes alternatives such as lubricants with low vapor pressure, unlubricated ceramic ball bearings, magnetic bearings, or aerostatic bearings using pressurized air.
  • One participant further elaborates on the concept of aerostatic bearings, proposing a design involving a centripetal turbine that utilizes air pressure for lifting and centering forces.
Participants express differing views on the viability of materials and bearing types for the proposed air motor, indicating that no consensus has been reached regarding the best approach or materials.
Participants note that wear characteristics can depend on various factors such as speed and pressure, and there are unresolved questions about the specific conditions under which the air motor would operate.
Individuals interested in mechanical engineering, materials science, and the design of air motors or similar applications may find this discussion relevant.
Mike_In_Plano
Hello,
I'm puzzling over the likelihood of building a dry-running air motor for 25khrs @5-20kRPM.
I'm considering whether a small gear pump arrangement would doe the job - it only needs to output 6 shaft watts, but I'm concerned about wear.
Standard gears are avalable in steel and delrin, and with a bit of searching, in ceramic. I'm wondering what would be a good combination of materials between the endplates and gear. It seems that the endplates would have to be under a bit of compression to ensure that the air leakage doesn't become excessive over time.
Does this seem a reasonable conjecture?
It also seems the endplates would be a complimentary material:
Steel vs teflon loaded delrin plate
Ceramic vs teflon loaded delrin plate
Delrin vs Hard steel
Finally, how would one go about accelerating wear testing?
Well, I guess that wraps it up (and then some :)
Best Regards,
Mike
The bearing material makers often have data sheets showing wear rates. Tho it can depend on speed as well as pressure and countersurface material. They may just show a few data points and leave you to guess the rest.
I see Dupont has a lot of leaflets online about Delrin's wear characteristics.
I'm kind of amazed at running a gear pump so fast. You can't use a centrifugal pump? You'd avoid a lot of the sliding sealing surfaces.
You have no single chance with a dry plastic bearing at 25,000/min. It would melt.
In case this is a matter of vapour pressure, some lubricants have an extremely low one. Use with plain bearings of sintered metal.
You may try with unlubricated ceramic ball bearings.
An other direction is magnetic bearings.
Or could you maybe use the pressurized air in a set of "aerostatic" bearings? Similar to hydrostatic ones, with big leaks, connected in series with your engine?
Thinking again at the aerostatic bearing...
Let's imagine your engine can be a centripetal turbine (you didn't mention that). Then you might inject the air at the periphery, use some of its energy contents to rotate the turbine, and let the air exit through the shaft at the bearings, where the remnant pressure gives lifting and centring force.
Maybe it doesn't fit your needs, but it's puzzling.
  • · Replies 33 ·
  • · Replies 45 ·
  • · Replies 82 ·
29K
  • · Replies 16 ·
13K
