Convergent Subsequences in Compact Metric Space
The discussion revolves around a sequence \( (x_n) \) in a compact metric space, specifically addressing the property that every convergent subsequence has the same limit \( x \). Participants are tasked with proving that \( x_n \to x \) as \( n \to \infty \).
  • Some participants explore the implications of subsequences and their convergence, questioning whether every subsequence must converge. There are attempts to use contradiction to argue that if \( x_n \) does not converge to \( x \), it leads to contradictions regarding the behavior of subsequences. Others discuss the necessity of subsequences converging to the same limit and the implications of compactness in the context of the problem.
The discussion is ongoing, with participants offering various lines of reasoning and questioning assumptions. Some have proposed approaches involving contradiction, while others are clarifying the requirements of the proof. There is recognition of the need to refine arguments for clarity and correctness.
Participants note the importance of definitions related to compact metric spaces and the nature of convergence. There is an emphasis on understanding the negation of convergence and the implications of subsequences in the context of the problem.
Chipz
Suppose that [tex](x_n)[/tex] is a sequence in a compact metric space with the property that every convergent subsequence has the same limit [tex]x[/tex]. Prove that [tex]x_n \to x[/tex] as [tex]n\to \infty[/tex]
Not sure, most of the relevant issues pertain to the definitions of the space. In this case I believe the following is relevant:
In a compact metric space every sequence must have a convergent subsequence, defining it as sequentially compact.
I'll add more.
My basic hang up is this: Does every subsequence have to be convergent? If so...you can.
Suppose not:
Assume there exists a subsequence [tex]s_n[/tex] in [tex](x_n)[/tex] s.t. [tex]s_m =\displaystyle\sum\limits_{k=1}^{m} x_k \to y \neq x[/tex]
Then there would exist an [tex]m>a>0[/tex]
Under the assumption that [tex]s_a = \displaystyle\sum\limits_{k=a}^{\infty} x_k \to x[/tex]
Where [tex]s_m = \displaystyle\sum\limits_{k=1}^{m+a} x_k[/tex] Would not be convergent.
Then the sequence [tex](x_n)[/tex] is not Cauchy, which implies it's not a Complete Metric Space.
how about contradiction? may need some tightening but general idea is there
assume xn doesn't tend to x, then either there it does not converge or it tends to y not equal to x
if it tends to y its clearly a contradication
now if it does not converge it still visits x infinitely often, but it must also be in the neighbourhood of some other point infinitely often (compactness) which is also a contradiction
That's essentially the proof I gave. Although I've revised it a little to be more true for subsequences rather than partial sums.
Let [tex](n_1>n_2>n_3...) \in \mathbb{N}[/tex]
Suppose [tex]lim x_n = x[/tex]
given any [tex]\epsilon > 0[/tex] we must find an [tex]N[/tex] s.t. [tex]j \ge N[/tex] then [tex]|x_n_j - x| < \epsilon[/tex] [tex]\forall n \ge N[/tex]
[tex]n_j \ge j[/tex] [tex]\forall j[/tex] by induction and [tex]n_1 \ge 1[/tex] because [tex]n_1 \in \mathbb{N}[/tex]
if [tex]n_j \ge j \to n_{j+1} \ge n_j \ge j \to n_{j+1} > j +1[/tex] so if [tex]j\ge N[/tex] [tex]n_j \ge N[/tex] then [tex]|x_n_j -x| > \epsilon[/tex]
And thus every subsequence needs to converge to the same value.
This appears to be a (confusingly written) proof that if [tex]x_n \to x[/tex] then every subsequence of [tex](x_n)[/tex] also converges to [tex]x[/tex]. Unfortunately that statement is the converse of what you are required to prove.
Begin with the hypothesis that every subsequence of [tex](x_n)[/tex] converges to [tex]x[/tex], and suppose that [tex]x_n \not\to x[/tex]. What does it mean for [tex]x_n[/tex] not to converge to [tex]x[/tex]? (What is the negation of the statement that [tex](x_n)[/tex] is eventually in every neighborhood of [tex]x[/tex]?)
(Use words! If your argument isn't essentially correct, symbols and abbreviations don't make it any clearer; they just make it harder to understand what needs fixing.)
