Solving Velocity Problems on the Moon
  • Thread starter Thread starter member 5645
    Velocity
The discussion focuses on solving a velocity problem involving an arrow shot upward on the Moon with an initial velocity of 58 m/s. The height of the arrow after t seconds is modeled by the equation H = 58t - 0.83t². Key calculations include determining the velocity at t = a, which is given by the formula 58a - 0.83a², and finding the time when the arrow hits the Moon, approximately 69.88 seconds, along with its impact velocity of 1957.04 m/s. The principles of energy conservation and the absence of air resistance are emphasized in the analysis.
  • Understanding of kinematic equations, specifically for projectile motion.
  • Familiarity with the concepts of kinetic and potential energy.
  • Basic algebra skills for solving quadratic equations.
  • Knowledge of gravitational effects on celestial bodies, particularly the Moon.
  • Study the derivation and application of kinematic equations in different gravitational fields.
  • Explore the concept of energy conservation in projectile motion.
  • Learn how to solve quadratic equations using the quadratic formula.
  • Investigate the effects of varying gravitational forces on projectile trajectories.
Students in physics, educators teaching kinematics, and anyone interested in understanding projectile motion in low-gravity environments like the Moon.
member 5645
Calc help - velocity problem...
Just looking to be pointed in the right direction, for now. I understand the equations I have learned about velocity, but am having trouble setting up this word problem:
If an arrow is shot upward on the moon, with a velocity of 58m/s, it's heigt in meters after t seconds is given by
[tex]H=58t-.83t^{2}[/tex]
Find the velocity of the arrow after one second? (I already figured this out)
Find the velocity of the arrow when t=a?
When will the arrow hit the moon? (I already figured this out)
With what velocity will the arrow hit the moon?
Set H = 0, solve for t then find the corresponding velocity.
Or, since energy is conserved and there is no air resistance then the kinetic energy will be the same at the end of the trajectory as it was at the beginning of the trajectory since the potential energy has a single value at the surface - therefore the speed is the same but the arrow is headed downward.
To find the velocity of the arrow when t=a, we can simply plug in a for t in the equation H=58t-.83t^{2}. So, the velocity at t=a would be 58a-.83a^{2}.
To find when the arrow will hit the moon, we can set the equation equal to 0 and solve for t. So, 58t-.83t^{2}=0. This gives us two solutions, t=0 and t=69.88 seconds. Since t=0 represents the initial position, we can disregard it and say that the arrow will hit the moon after approximately 69.88 seconds.
To find the velocity at which the arrow hits the moon, we can plug t=69.88 into the equation for velocity, which would give us a velocity of 58(69.88)-.83(69.88)^{2}=1957.04 m/s.
I hope this helps point you in the right direction and gives you a better understanding of how to approach velocity problems. Remember to always carefully read the problem and identify what information you have and what you need to find. Then, use the appropriate equations and plug in the given values to solve for the unknown variable. Good luck with your calculations!
  • · Replies 20 ·
