Divergence Theorem: Check Function w/y^2, 2x+z^2, 2y
The discussion revolves around verifying the divergence theorem using the vector function \(\mathbf{v} = y^2\mathbf{\hat{x}} + (2xy + z^2) \mathbf{\hat{y}} + (2yz)\mathbf{\hat{z}}\). Participants are examining the divergence of this vector field and its relation to surface integrals.
  • Participants discuss the correct application of the divergence operator and question the treatment of variables during differentiation. There is confusion regarding the dot product and the resulting terms from differentiation.
Some participants have provided clarifications on the nature of partial derivatives and the need to treat other variables as constants during differentiation. There is ongoing exploration of the integration process and its implications for confirming the divergence theorem.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The discussion includes questioning assumptions about the differentiation process and the setup of integrals.
vorcil
Check the divergence theorem using the function:
[tex]\mathbf{v} = y^2\mathbf{\hat{x}} + (2xy + z^2) \mathbf{\hat{y}} + (2yz)\mathbf{\hat{z}}[/tex]
[tex]\int_\script{v} (\mathbf{\nabla . v }) d\tau = \oint_\script{S} \mathbf{v} . d\mathbf{a}[/tex]
taking the dot product it becomes
[tex]\frac{\partial}{\partial x} y^2 \mathbf{\hat{x}} + \frac{\partial}{\partial y} ( 2xy + z^2) \mathbf{\hat{y}} + \frac{\partial}{\partial z} (2yz)\mathbf{\hat{z}}[/tex]
so by only differentiating the certain parts:
i get y^2 + 2x + z^2 + 2y,
however the dot product of del and my vector v, should've been 2(x+y)
how come I've got y^2 and z^2?
does [tex]\frac{\partial}{\partial x} y^2[/tex] not equal y^2?
Your divergence should not actually include any vectors. It's just a number. So you should have
[tex] \frac{\partial}{\partial x} y^2 + \frac{\partial}{\partial y} ( 2xy + z^2) + \frac{\partial}{\partial z} (2yz)[/tex]
Once you take the dot product
Then it looks like you differentiated your unit vectors as though they were variables
[tex]\frac{\partial}{\partial x} y^2[/tex] is 0, not y2
this isn't correct, you applied a dot product, it should be
[tex]\frac{\partial}{\partial x} y^2 + \frac{\partial}{\partial y} ( 2xy + z^2) + \frac{\partial}{\partial z} (2yz)[/tex]
to see where you went wrong, what is
[tex]\frac{\partial}{\partial y} z^2[/tex]
Is it 0? is that because z^2 is a constant since it's being differentiated with respect to y?
and d/dx of a constant is 0?
now knowing that [tex]\frac{\partial}{\partial y} z^2 = 0[/tex]
I think I can solve the rest,
[tex] \int_\script{v} (\mathbf{\nabla . v }) d\tau = \oint_\script{S} \mathbf{v} . d\mathbf{a} [/tex]
so
[tex]\oint_{\script{V}} 2(x+y) d\tau[/tex]
taking the constant out and making tau dxdydz = [tex]2 \int_0^1 \int_0^1 \int_0^1 (x+y) dxdydz[/tex]
separating the three integrals out, (i think I can do that?)
dx part: [tex]\int_0^1 (x+y)dx = \left[ \frac{x^2}{2}+y \right]_0^1 = (\frac{1}{2} + y)[/tex]
dy part, using the result of the dx part:
[tex]\int_0^1 (\frac{1}{2} + y) dy = \left[ \frac{1}{2} + \frac{y^2}{2} \right]_0^1 = (\frac{1}{2} + \frac{1}{2})[/tex]
dz part using the result of the dy part:
[tex]\int_0^1 (1)dz = \left[ 1*z\right]_0^1 = 1[/tex]
bringing in the constant 2, of what I brought outside the integral,
[tex]\int_{\script{V}} \mathbf{\nabla . v} d\tau = 2[/tex]
so that means the integral of a derivative over the vector is equal to 2,
and to confirm the divergence theorem,
I also need to integrate over a closed surface for the cube?
that means i need to solve for 6 integrals,
yes that is the definition of a partial derivative, the other variables are held constant
It does indeed require you to compute 6 double integrals over the surface of the unit cube.
not sure why you would separate it, anyway though you get the right answer (luck), the integral isn't correct. y is treated as a constant, what is the integral of a constant?
oh right, I should've separated and differentiated each bit individually,
so \int x dx, |_0^1
then added \int y dy |_0^1 to it
and then multiplied by int dz,
no i meant
[tex]\int_0^1 dx y = yx|_0^1 = y(1-0) = y[/tex]
just treat it as
[tex]2 \int_0^1 \left(\int_0^1 \left(\int_0^1 (x+y) dx\right)dy\right)dz[/tex]
