Factors Effecting Boil-Off of Liquid
  • Context: Undergrad
  • Thread starter Thread starter Gremlyn1
    Factors Liquid
The discussion revolves around the factors influencing the rate of liquid loss during boiling, particularly in the context of home brewing. Participants explore the impact of pot width, energy input, surface area, and environmental conditions on evaporation and boiling processes.
  • One participant argues that while energy input is important, the increased surface area of a wider pot contributes to higher evaporation rates, as evaporation occurs at all temperatures.
  • Another participant contends that the boiling temperature of the liquid cannot exceed its boiling point unless pressurized, suggesting that surface area primarily influences heat absorption rather than loss rate.
  • A different viewpoint suggests that the shape of the pot can affect heat absorption efficiency, with a wider base potentially trapping more heat from the burner.
  • Concerns are raised about the simplification that two pots with different widths would lose the same amount of liquid under equal energy inputs, emphasizing the role of evaporation and environmental factors like wind and humidity.
  • One participant clarifies the distinction between boiling and evaporation, stating that evaporation occurs below boiling point and is influenced by environmental conditions, while boiling is a direct result of heat input at the pot's bottom.
Participants express differing views on the relative importance of energy input, surface area, and environmental factors in determining liquid loss during boiling. No consensus is reached, and multiple competing perspectives remain active in the discussion.
Participants acknowledge that various external factors, such as wind and humidity, can influence evaporation rates, complicating the analysis of boiling loss in practical scenarios.
Gremlyn1
Hi all,
I came across your forum looking for some help to settle a debate. A few fellow home brewers and I are debating what factors influence the rate of loss during a boil. The original question came from a brewer who switched to a wider pot and discovered that he lost more liquid over the course of his hour long boil than he previously did with his old pot.
The side opposing me on the debate is stating that the ONLY thing that matters is how much energy is put into the liquid and the wider pot simply manages to use the heat more efficiently.
I say that while the energy put into the system is certainly an important factor, the extra surface area of the wider pot has to come into play because evaporation occurs at all temperatures, and of course occurs faster a higher temperatures.
Sooooooo, who is right and why?
Thanks for your time!
Science news on Phys.org
Welcome to PF, Gremlyn.
The liquid itself can't rise above its boiling temperature, regardless of how much heat you put in, unless it is pressurized. A wider pot might reach that temperature sooner, but it's moot after that. I therefore agree that the surface area determines loss rate.
Someone better educated might have a different opinion, though, so wait to hear from them before running off in triumphant joy.
Yes, the only thing that matters when you are boiling in a container open to the atmosphere is the [net] rate of heat absorption. However, the shape of the pot can affect the rate of heat absorption: a wider base may effectively trap more of the heat from the heat source, such as a burner. Ie, if the flames are licking-up the sides of the pot instead of being fully underneath it, a very substantial fraction of the heat will be lost to radiation and convection around the pot.
So you're saying two pots with different widths will lose the exact same amount of liquid in a give time given equal energy inputs. Why is it that evaporation plays no part? And just to be clear, we're not talking about some perfect system in controlled conditions. There are many factors like wind, humidity, etc also at play.
Because "boiling" and "evaporation" are not the same thing. When water evaporates, it is below its boiling point and water vapor comes off the surface due to interaction with the air above it. Wind and humidity have an enormous impact on this interaction.
But when water boils, water is converted from liquid to gas by the heat input at the bottom of the pot. How fast that water vapor is generated is a function only of the heat input. Once created, the bubbles of water vapor rise through the pot and are released into the air, regardless of what is going on above the pot. Since the temperature of the bubbles is above the boiling point, not even 100% humidity above the pot can keep those bubbles of water vapor from being relesed into the air.
  • · Replies 32 ·
  • · Replies 23 ·
